03-05-2020, 12:01 PM | #1 |
Rep 45
Wheels and tires
It's getting warm out, so 'tis the season to buy some wheels and tires. Unsure of what to go with and the widths/offsets I should seek. I'd maybe like some of the flow-formed HREs, but they have a bit of a hefty pricetag to go along with them.
So those of you who have aftermarket wheels, can you supply some pics and fitment specs? I've trolled through the stickied modded thread, but there weren't a ton of specs listed. Last edited by rxryanm.; 03-21-2020 at 11:18 AM.. |
03-09-2020, 04:25 AM | #2 |
Rep 121
I was leaning towards same issue, thought that would like to buy semi light alloys and found flow forming sets at sensible price tag ( both sets round a grand each). Summer ones (19x8,5 et 30/ 19x9,5 et et 37) not tried yet, winter ones (18 x 8 et 35) working perfectly .... or even better ( softened/narrowed tire too vs. former set) while being over 10 pounds lighter (each combination) suspension is also upgraded to an other level.
I'm eagering to experience how would summer set feel while the weight loose is to be even bigger. My car is 'floating' high while still being in normal height (X-Drive with those high base springs), the outlook is getting better after my Eibach 20/25 mm set is installed. Last edited by TON-III; 03-09-2020 at 04:36 AM.. |
03-15-2020, 08:23 PM | #4 |
Rep 284
I asked my SA to price some new Michelin Pilot Sports. He replied that BMW would not install non-run flats on my 650. If I replace the run flats with non run flats do I run the risk of losing Warranty coverage on items related to tires, i.e., suspension?
03-15-2020, 08:35 PM | #5 |
Rep 404
Yeah, no. There is no way they can void any warranty claims over tires. You need to find a different shop, your dealer sounds less than helpful.
03-15-2020, 08:38 PM | #6 |
Rep 631
how long do you have left on your warranty. There is ZERO proof that non-runflats will adversely affect the performance or life of your suspension. That is a bunch of what the bull just dropped off. These cars have no suspension problems from what I know. If you are going to change, go to the MPS 4S. They are an improvement and are quieter than the MPS.
F06 M6 Grand Coupe CP
03-15-2020, 09:39 PM | #7 |
Rep 239
Rennen Forged 20x10 et37; 20x9 et29 - These wheels were much less expensive than you would typically spend on forged wheels
2014 BMW 650GC M sport
2011 BMW 550i M-sport/AW 1991 Nissan 300ZX Twin Turbo 2007 Chevrolet Corvette Z51 (sold) 2001 BMW 325ci (sold) |
03-16-2020, 07:29 AM | #8 |
Rep 121
In my opinion the suspension is up to brake WHEN you've the RF's under, those are so tough that all the bumps are hitting to your car body. With normal type of tires the tire absorbs part of bumbs.
03-16-2020, 07:20 PM | #9 | |
Rep 284
03-16-2020, 07:52 PM | #10 |
Rep 631
The competition package comes with PSS from the factory. How can it be unacceptable to put them on your car.
I think he must be an alternative reason for his statement
03-16-2020, 09:00 PM | #11 |
Rep 284
Does it come with a spare? There is a tire dealer in MA that wont put non run flats on a car that comes with run flats unless you sign your life away. While I believe BMW states the cars design includes run flats the tire dealer is concerned about the liability of someone getting a flat and being stranded with no spare.
03-19-2020, 04:28 PM | #13 | |
Rep 57
Drives: BMW 650i xDrive
03-20-2020, 02:38 PM | #14 | |
Rep 7,525
03-21-2020, 08:44 PM | #15 |
Rep 284
03-21-2020, 09:04 PM | #16 |
Rep 2,349
F10 M5 343m or 601m. Cheap and the 343m are very light too.
03-27-2020, 03:39 AM | #20 | |
Rep 106
Hey, I noticed you have an X-Drive (as do I) this makes things a little more complicated when buying wheels. I'm no mechanic, but it's my understanding you have to keep an eye on "rotational mass" of the tires (I think!) They all have to be within a certain % of each other. I believe it's called "rotational mass" Regardless, there are calculators online to figure it out. I just wanted to give you a heads up, if you didn't already know about this. If the tires aren't the correct sizes, you'll have issues with your transfer case. If I'm wrong, someone please correct me. I just wanted to give you the heads up. |
03-27-2020, 08:46 AM | #21 | ||
Rep 289
You want the front and rear wheels to be spinning at the same RPM for AWD otherwise you risk burning through the differential, correct me if I'm wrong on that statement. Rotational mass comes into play with the weight of the wheels which can 'free up' some horsepower when you go lighter. You won't be gaining BHP, but transferring more power efficiently to the wheels so you'll see an increase in your WHP. Think of lightweight flywheels and driveshafts etc, takes less energy to spin. Going back to wheels, imo 21" are the perfect size. You see majority of M6s go with that size. 20" is nice, but more conservative. 22" you could be sacrificing a lot of ride quality. |
03-27-2020, 08:33 PM | #22 | |
Rep 1,698
When I did this (last summer), the car was 2.5 years old - so still under warranty. There was no discussion or threat that changing to non runflat would void anything with the warranty. I don't believe that argument would hold up very well if challenged. You could argue that a Bugatti's tires, meant to withstand incredible speed (beyond a traditional tire) would void a warranty if changed, but you'd be hard pressed to convince anyone that a like-for-like spec (size, speed rating, load rating, etc) on a "normal" car like a BMW would call for voiding anything.
