      03-04-2020, 09:51 AM   #1
Flying Ace
Flying Ace's Avatar
4985
GC Brake light recall
Apparently certain models have an open recall:
RECALL CAMPAIGN NO.
20V-094
STATUS
Remedy Unavailable
ISSUED
Feb 19, 2020
LAST UPDATED
Mar 04, 2020
Description Of Problem
The Third Brake Lamp May Become Loose.
Safety Risk
Over Time, The Lamp Could Detach Which Could Become A Road Hazard For Other Drivers And Increase The Risk Of A Crash.
Description Of Repair
The Third Brake Lamp Will Be Secured With New Fasteners For Free Which Should Take Approximately One Hour.
BadSeed158.00
plm36.50
      03-04-2020, 12:43 PM   #2
plm
Drives: M6 GC
I saw here on another post recently that someone had their third brake light fly off on the freeway and was asking if anyone had a link to where to get a replacement part. That's crazy.
Oh, and mine's affected as well. Best get it booked in then.
      03-04-2020, 01:06 PM   #3
mikerx5
mikerx5's Avatar
461
Drives: 2014 F06, 2022 G06
How can you check?
      03-04-2020, 01:18 PM   #4
Flying Ace
Flying Ace's Avatar
4985
Originally Posted by mikerx5 View Post
How can you check?
Call your VIN into your local dealership service department
      03-04-2020, 02:11 PM   #5
plm
Drives: M6 GC
Or type your VIN into this page:
https://www.bmwusa.com/safety-and-emission-recalls.html
      03-04-2020, 08:27 PM   #6
ep3
Drives: 07 335i and 14 M6
Looks like it's only the GC models.
https://static.nhtsa.gov/odi/rcl/202...0V094-7207.pdf
https://static.nhtsa.gov/odi/rcl/202...0V094-3935.PDF
One doc says 2014-2019 and the other mentions 2016-2019. Couldn't locate the relevant SIB.
      03-04-2020, 09:14 PM   #7
Flying Ace
Flying Ace's Avatar
4985
Ah, that makes sense. The GC brake light is on the roof and coupes and certs have light on the trunk.
Both docs say 2014-19
      03-05-2020, 09:46 AM   #8
ep3
Yeah, I was looking at my coupe and wondering how that could be defective until I read the docs. In the second link, on page two under chronology it says 2016-2019, but conflicts with the previous portion of the document.
      03-05-2020, 10:16 AM   #9
mikerx5
mikerx5's Avatar
461
FYI in RI there is no fix for this yet. My GC does need the recall however
      03-05-2020, 02:21 PM   #10
EnVe46
EnVe46's Avatar
1038
Drives: 11 E90 M3 LeMansBlue
Mines in the recall. Not going to jump for the opportunity to go to a dealer that's for sure
2011.5 E90 M3
LeMans Blue
      03-06-2020, 12:24 AM   #11
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
Bought mine a week ahead of the recall as mine went flying off the window, struck the rear of the car pretty hard a few time and leapt to its death. Cost me 600 bux with expedited shipping. My son and I did the install in less than an hour.
Flying Ace4984.50
      03-06-2020, 12:24 PM   #12
plm
Drives: M6 GC
You should go after BMW for reimbursement, plus you'll also want to do the recall when they get the new kits ready as they're going to be improving the fixing method so it can't happen again.
      03-06-2020, 05:34 PM   #13
TinCanSailor
630
Drives: F06 M6
I am going to go to the dealership tomorrow to at a minimum get my money refunded. In the US the TREAD ACT covers owners for such situations and I was told this by BMW USA so I am pretty sure I'll be made whole there. I did have some paint scuffing on the trunk so I am going to see if they can do anything for the blemish.
Flying Ace4984.50
      03-07-2020, 08:14 AM   #14
Are owners that fall into the build date range checking their 3rd brake light to see if it is loose?
      03-10-2020, 08:10 AM   #15
TinCanSailor
630
Drives: F06 M6
I hope they are because when this happened to me I was in the interstate and I suspect this is going to occur at or above 70 and it is a very unsettling sound and feeling.
You can get the plastic cover off the rear center headliner very easily. Remove that and the gently pull the ribbon cable from the module. Unbolt the module and check those two nuts. Then run your finger between the headliner and the roof to feel for the remaining nuts. You will feel a circular cutout for each bolt hole.
I wouldn't attempt to pull the aux brake light out because it can be a real pain in the Auxhole to get the rubber trim properly back into place.
      03-20-2020, 06:45 PM   #16
936F06
Drives: 2014 M6 GC
Doing my recall tomorrow at my local bmw stealership!��
      03-22-2020, 09:11 AM   #17
MetZF82
Drives: 2015 F06 M6
Thanks I just checked my vin and this does show up.
      03-27-2020, 06:00 PM   #18
BLACK KILLER
BLACK KILLER's Avatar
Germany
90
Drives: BMW'16 M6GC
Made on BMW. Yesterday. Hello from southern Germany
Flying Ace4984.50
      04-01-2020, 05:00 PM   #19
Anand06
Drives: F06grand coupe M6
3rd brake light recall
My car was one that needed the fix.Took it to my local, dealership who sorted it out. No dramas
      04-01-2020, 10:02 PM   #20
brad850csi
Drives: 16 F13 M6 Comp
MelbourneFinn Saw this was a recall in AU now too
      04-02-2020, 02:35 AM   #21
MelbourneFinn
MelbourneFinn's Avatar
Drives: 2021 G30 M550i
2021 BMW M550i  [9.00]
Thanks, I hadn’t seen the AU recall, supposed to go in for extra oil change next Wednesday, best they do this as well. Thanks!
      04-04-2020, 06:29 PM   #22
plm
Drives: M6 GC
Got mine done today. Was in and out of the dealer in under an hour, and that also included them doing a couple of other minor things for me, so it's a pretty straightforward fix.
