      03-26-2015, 09:27 PM   #1
yipyip99
Drives: 2015 F13 Coupe
Staggered wheels on 640xi?
So I have a set of Matte Black Giovanna Kilis 20x8.5 front, 20x10 rear.
Good or Bad? :
      03-26-2015, 11:17 PM   #2
bravo261
Drives: F06 650
i don't know if its truly bad, let alone how bad, but if they came square, probably leave them square.
but, during the summer, i might try staggered if i were in your shoes and see how it goes
      03-28-2015, 06:33 PM   #3
jwblack750
MBACPA
Drives: 2014 640xi Gran Coupe
Good or Bad? :
The overall diameter of the tire needs to be very close (use this http://www.rimsntires.com/specspro.jsp). That should also help you determine if the 10" wheel will fit, too (be sure to enter the offset).
I run staggered on my 640xi, and I recall them being 20x8.5 and 20x9.0, and 245/35/20 front and 275/30/20.
      03-28-2015, 07:35 PM   #4
Downfourit
Drives: M6 Gran Coupe`
What are the offsets front and rear?
      03-29-2015, 05:26 PM   #5
yipyip99
Good or Bad? :
Thanks for the great advice!
I have the same tire sizes as you. Only the rear rims are a little bigger. 20x10.
I had them on my E90, so they will definitely clear on the F13.
I just don't want to mess up the tranny or drivetrain.
I was also thinking maybe run the car on sport+ mode which shuts off the awd system and the car becomes a rwd.
We'll see...
      03-29-2015, 10:03 PM   #6
jwblack750
MBACPA
We'll see...
No problem, and just so you know, I am 95% sure that the tires I am running are the same tires that come on the x-drive version when you get the 20" wheels. So, I think BMW approves of our setup! Maybe someone with x-drive and 20" wheels can confirm that for us, though.
      03-30-2015, 06:11 AM   #7
WWnyc
Drives: 2014. 640 ix Vert
We'll see...
Sport + shuts off the AWD ?
Are you sure? I don't think so 😳
      03-30-2015, 09:24 AM   #8
Bönz
Bönz's Avatar
Drives: 2018 M5
Are you sure? I don't think so ��
You are correct. XDrive is always engaged. While under certain conditions it may transfer up to 100% of the engine's torque to the rear, it cannot be turned off.
      03-30-2015, 11:16 AM   #9
yipyip99
What's your technical explanation as to why you can then drift on sport+ mode?
      03-30-2015, 11:16 AM   #10
poloka
Drives: 540xi
We'll see...
Correct, sport+ only will take off traction control. AWD is still engaged.
BMW CCA: 501218
Current owned:
2018 540xi MSport
Previously owned:
2015 650xi Gran Coupe MSport
2011 X5 50xi MSport
      03-30-2015, 11:17 AM   #11
yipyip99
Rim Diameter: 20
Rim Width: 8.5-10
Section Width: 8.5 FRONT 10 REAR
Offset: LOW and HIGH
Bolt Pattern: 5-120, 5x112, 5x114.3
Hub Bore: 72.56 66.56 74.1
      03-30-2015, 10:58 PM   #12
jwblack750
MBACPA
Rim Diameter: 20
Rim Width: 8.5-10
The offset is going to be a 2-digit number. Mine are 33 front and 44 rear. It will often have ET before the number. You would have needed to enter those numbers in the http://www.rimsntires.com/specspro.jsp site to see if the 10" wheel would cause any issues. The front wheel shouldn't be any problem.
      03-31-2015, 07:26 AM   #13
yipyip99
Rim Diameter: 20
Rim Width: 8.5-10
Thank you so much for the info
I know the rims will clear without any problems.
My concern is the effects of having staggered wheels on an awd vehicle.
Would it kill the transmission or the drivetrain? :
      03-31-2015, 08:37 AM   #14
troymi
Drives: '15 M235i Convertible
Simple answer: No. BMW offers the X drive coupe with optional staggered 20" setup.
      03-31-2015, 10:47 AM   #15
Bönz
Bönz's Avatar
Drives: 2018 M5
AWD does not preclude oversteer, especially with the nannies turned off.
      12-02-2019, 10:33 PM   #16
4collins
4collins's Avatar
Drives: BMW 640i Xdrive
2015 640ix Staggered Question
I am interested in putting staggered rims on my 6. I have seen a lot of info about it and I know it is possible to do without damaging the xdrive. I am looking at some wheels that are 20" x 9"et35 front and 20" x 10.5"et38 rear's with a 72.6cb. Any idea if this setup will damage anything?
      12-03-2019, 01:49 PM   #17
Probably not since those numbers are really similar to the BMW oe staggered wheel set-up...but a quick 2-4 minutes inputting your data into a wheel/tire calculator (compare the old front axle to the new axle...then do the same for the old rear & new rear set-up) at this site (or any other wheel/tire calculator site...and you'll see how much "poke" or "inset" the new set-up will have vs the old set-up: www.willtheyfit.com
BTW...what is the wheel bolt pattern? The f06/f12/f13 six series has a 5x120mm wheel bolt pattern...if you're going to use a wheel with a different wheel bolt pattern, you may need to use some type of adapter...so its dimensions will also need to be added to your calculation.
      12-04-2019, 12:37 AM   #18
TON-III
Drives: BMW 640 DA X-Drive M-Sport -12
It's quite 'normal' to have mixed sets in the 'show' cars but as said X-Drive does not take much tolerance between front and rear tires, in the end it's the same what charts says other 275/35/19 tire can have bigger outsize than other so it's an risk always.
With X-Drive it would be wise to have same tire in every corner ...... but as many of us I'm riding mixed 245/40/19 front / 275/35/19 rear summer tires.
