      10-08-2020, 12:04 PM   #1
patchesj
patchesj's Avatar
68
Drives: BMW M6
M6 vs M5 intake crossover pipe?
Interesting that it looks like the M5 has a tube that connects the two elbows before the charge coolers, and the M6 does not have this. I can only assume this is to balance the pressure across both side of the motor. Any thoughts on why the difference? I didn't realize there were significant variations between the S63tu installed in the M5.
      10-08-2020, 01:59 PM   #2
Flo1989
Flo1989's Avatar
342
Drives: M6 Gran Coupe
That’s a F90 M5, not F10.
      10-08-2020, 02:05 PM   #3
patchesj
patchesj's Avatar
68
Drives: BMW M6
Ah Bingo... That makes more sense.
      10-08-2020, 07:19 PM   #4
Flo1989
Flo1989's Avatar
342
Yup. The F90 and new M8 share the same engine lay out as well.
      10-18-2020, 10:30 AM   #5
Aliendex
Aliendex's Avatar
Italy
39
Drives: M6 F06
Aside from the fact that the S63TU4 is completely re-engineered from the S63TU in our F10/F06/F12/F13
I'm still wondering the exact same question as the OP.
Does the tube equalize pressure between the two banks?
Why is that?
My S63TU datalogs doesn't show much difference between the two banks in relation to manifold and pre-throttle boost
      10-18-2020, 10:47 AM   #6
patchesj
patchesj's Avatar
68
Drives: BMW M6
One additional thought on how there might be a small feedback loop built into the system for equalizing pressures... The novel hot V mounting allows for exhaust pulses from both banks to drive the turbo. If it was just the left side driving the left turbo, pushing air into the left side, no systematic balancing happens and some other form of intake equalization would be necessary. Regardless, there must be some benefit to it or they wouldn't have put it there on the TU4.
I am curious though, I didn't think the TU4 was "completely re-engineered"?? The differences all seem to be fairly minor from the TU0?
      10-18-2020, 11:15 AM   #7
patchesj
patchesj's Avatar
68
Drives: BMW M6
From what I can tell the changes in the turbos, exhaust manifolds, downpipes, etc. are not actually significant. The fuel injectors, well that is different. But I still wouldn't say completely re-engineered.
Some info I found here:
https://f10.m5post.com/forums/showthread.php?t=1432202
Notable new parts include:
- New Engine Oil System
- New Intercoolers (Bigger)
- New Fuel Pumps and Fuel Injector designs which now pump at 350bar instead of 200bar in the F10 M5.
- New Turbos
- New Exhaust Manifolds for the Turbos
- New Downpipe Design
      10-20-2020, 08:45 AM   #8
RagtagXMASTER
RagtagXMASTER's Avatar
119
Drives: 2013 M6
I dont think its as extensive as that. the oil system is a little different, not much, has a more piston oil holes, the ICs are a little different with pressure balance being the main change. fueling is in fact different, and a great upgrade.
the exhaust and turbo setup is a little different to accommodate the ZF auto, but the turbos are very similar to the Tu2, which were already similar to the tu. the non tu s63 is vastly different.
thats what i get after reading all the technical documentation across the different engine variants. unless im starting the blend them all now
      10-20-2020, 09:02 AM   #9
patchesj
patchesj's Avatar
68
Drives: BMW M6
Yep, oiling/piston changes to further reduce oil consumption. IC's for increased airflow and pressure balance. turbo/downpipe changes to get around the larger bell housing.
The higher fuel rail pressures would be the only thing that could have significant impact on performance, IMO. (potentially removing HPFP problems on 800+ HP builds...)
TU0-2-4 are all incremental improvements, not re-designs.
