      05-27-2022, 02:39 PM   #507
titomi
titomi's Avatar
Drives: X3 G01 30i xDrive
2018 X3 G01  [0.00]
I'm in the notifications section, open the notification, and then press back button, it takes me straight to the news page. Shouldnt it take me to the notifications section main window?
Or if I press the notifications button, it should do the same (open main window of the section)
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
      05-27-2022, 02:47 PM   #508
apptest
Private2
apptest's Avatar
Drives: BMW M3 F32 Coupe!
Is this for a notification that you clicked on from a push notification and opened the app that way, or were you already in the notification page and clicked to open a thread?
Test 23456rt
      05-27-2022, 02:55 PM   #509
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Already in the page.
      05-27-2022, 03:14 PM   #510
apptest droid
apptest droid's Avatar
Are you pressing back button on the top left or the android system back button?
BMW is great
      05-27-2022, 03:26 PM   #511
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Android button on the phone (Samsung, Android 11). It behaves the same when I open the thread directly from the notification.
apptest2999.00
      05-27-2022, 08:18 PM   #512
MadBimmeRad
MadBimmeRad's Avatar
Drives: M235i, 420i, and now the M2 CS
There's an arrow on top left hand side of the page to go back within the notifications. The Android back button on the bottom left hand side takes you back to, what I'd call, the root directory which is the news page
M2CS,
The second coming of ///M!
apptest2999.00
      05-27-2022, 09:10 PM   #513
apptest
Private2
apptest's Avatar
Ok this was a great report. I believe I’ve fixed the issue and it revealed some larger issues we had with push notifications, which I’ve also fixed.
Tapping on push notifications when the app is closed should be much improved for taking you directly to the notification (for example opening a post or PM).
I’ve just released version 5.2.35 which contains the new fixes, let me know if its still not working for you
Test 23456rt
titomi926.00
      05-28-2022, 12:58 AM   #514
titomi
titomi's Avatar
2018 X3 G01  [0.00]
I know about that. But is that the desired behavior for the Android button ? Looks like developers agreed with me, that it's not.
      05-28-2022, 01:16 AM   #515
titomi
titomi's Avatar
2018 X3 G01  [0.00]
I believe it's fixed, at least for the part I reported (Android back button now takes you back to the notifications section)
Good job!
apptest2999.00
      05-28-2022, 01:56 PM   #516
apptest
Private2
apptest's Avatar
Looks like the performance went down with the latest updates. The app is slower, when I owned after some time. It takes longer to load forums list, forum threads, news, etc. I'm on the latest version and wifi connection, using Samsung device with Anddiid 11.
Hi, I just released version 5.2.36 which tries to clear memory a lot faster then before. Maybe this has to do with what you mentioned, as I think you are saying performance gets worse over time? The more you use it the worse performance gets correct?
Try 5.2.36 and see if it improves performance for you at all?
Test 23456rt
      05-29-2022, 03:29 AM   #517
titomi
titomi's Avatar
2018 X3 G01  [0.00]
It's worse I really need to download an app and make a screen recording. Samsung removed the native option.
apptest2999.00
      05-29-2022, 10:45 PM   #518
MadBimmeRad
I'm no longer helping push notifications even though it's selected in my app and shows as active
M2CS,
      05-29-2022, 11:51 PM   #519
apptest
Private2
apptest's Avatar
I recently made some changes with push but was hoping it didn’t affect anyone. Maybe it did. You could try to either click on repair push notification option or just turn push off and then turn it on again and see if it helps?
Test 23456rt
      05-30-2022, 01:49 AM   #520
MadBimmeRad
Somehow, it's stated behaving again (without intervention)
M2CS,
apptest2999.00
      05-30-2022, 01:50 AM   #521
apptest
Private2
apptest's Avatar
That's always the best solution 👌
Test 23456rt
      05-30-2022, 12:27 PM   #522
titomi
titomi's Avatar
2018 X3 G01  [0.00]
When opening this thread from the news page, it remains open for a few seconds and then the app crashes, without any warning or information. Tried it numerous times. Didn't noticed this anywhere else.
apptest2999.00
      05-30-2022, 01:24 PM   #523
apptest
Private2
apptest's Avatar
I’ve never seen more images in a single thread before. So I think that’s the reason. Maybe your device is running out of memory in some way. My Samsung S20 is doing great with it, but I’m going to investigate this some more.
How are your other issues doing with the endlessly loading circles, are they now resolved after yesterdays update?
Test 23456rt
      05-30-2022, 01:32 PM   #524
titomi
titomi's Avatar
2018 X3 G01  [0.00]
It's back to how it was, so better. You might be right about my phone. It's sometimes very laggy, which wasn't the issue before. Although it says the I have plenty of memory (both of them).
apptest2999.00
      05-30-2022, 09:50 PM   #525
snareman
Leave the gun. Take the Canoli.
snareman's Avatar
Drives: ///M8 & X3 ///M40
Not sure if this has been said...
On the website you can click near the top of the thread you are in to take you back to the main page for that particular forum, but there is no way to do that in the app. If I click to a thread from the notification page in the app the only option seems to be to click the back button which takes you back to your notification list.
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40
Retired:
2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe
      05-30-2022, 10:16 PM   #526
apptest
Private2
apptest's Avatar
Conceptually, if someone opens a thread from their notifications and they hit back, they will most likely want to go back to see the rest of their notifications.
Hitting back and going back to the main forum from a notification would end up confusing and frustrating most people IMO. In that scenario, how would you go back to viewing the rest of your notifications?
Test 23456rt
      05-30-2022, 10:41 PM   #527
snareman
snareman's Avatar
I agree. It couldn't be the same button. The back button should take you back to your notifications but on the website forum you can either click on the thread title or the particular form name at the top and there's not really a place to do that in the app. Just seems like something that would be handy if you get into a forum by the notification and then just want to go view the rest of the threads in that forum.
Retired:
apptest2999.00
      05-30-2022, 11:29 PM   #528
apptest
Private2
apptest's Avatar
Ok I see what you are suggesting, a secondary navigation system at the top of threads. Something like that would not be that difficult to put into action. But I’m not sure about it. Mainly because it would go against the clear navigation strategies inherent in apps. Let me think about it some more and see if there’s a way to do it while maintaining a straightforward navigation strategy 👍
Test 23456rt
snareman9051.50
