09-09-2019, 12:58 AM | #23 | |
Rep 767
Thank you for the info. The ‘19 wheels that I want to use are not OEM and I know that I have to use hubcentric rings (I had these rims on my E90). The thing that I did not know was the percentage (+/- 3%) of the new tires diameter/circumference that I do not have to exceed. Thak you again.
09-09-2019, 07:45 AM | #24 | |
Rep 7,475
I say that because sometimes the hub rings will stay on the hub when the wheels are removed...and sometimes they come off with the wheel. If they don't know that the rings are there...they can get damaged or lost which can screw up your remounting of the wheels. And if by unfortunate circumstance, the rings get damaged anyways (sh!t happens)...if you've told them about the rings, then they are on the hook for replacing them.
jjasonSU194.00 |
08-03-2022, 11:19 PM | #25 | |
Rep 20
https://www.6post.com/forums/showthr...3#post29171603 |
08-03-2022, 11:25 PM | #26 | |
Rep 20
Great video! Very helpful. Maybe you can offer some insight on why my front 22's are rubbing on my control arms... I have 22x9 +30 offset (supposedly), 245/30/22 tires. I'm thinking an 8-10mm wheel spacer may fix the issue or I was sold the wrong rim offset by accident? Dont know gonna try and measure it. I see tons of 650i running 22's (jjasonSU) with my tires size with no issues.. either everyone is lying or something is bad wrong with my setup... |
