04-26-2018, 08:54 AM | #1 |
Rep 300
SOUL | M6 Resonated Muffler Bypass Exhaust
CONSTRUCTION: Each set of muffler bypass pipes is made from mandrel bent T304L 3″ .065″ wall stainless steel tubing, straight through race resonators with a full metal packing design for maximum durability, and laser cut brackets for perfect fitment. Choose from several hand finished tip options to get the look that suits your M6 best. Mikalor Supra Heavy-Duty Clamps are included to securely hold the tips onto the system. POWER: Our development M5 reached peak power of 610 whp and 615 ft-lbs of torque during third party dyno testing at R/T Tuning. Mods included catless downpipes, custom tune, and our Resonated Muffler Bypass Exhaust. Power gains are identical as the M6 uses the same 4.4L V8. BOLT ON AND GO: Each exhaust is tested in a fixture to ensure perfect fitment. Installation requires cutting the original exhaust at a factory break point (marked with a dimple) which allows for reinstallation of the factory system if necessary. Thorough installation instructions are included in the box for a straightforward install that can be performed by most DIY enthusiasts. LIFETIME WARRANTY: Enjoy your Soul exhaust components with confidence on both the street and track as they are covered by our Lifetime Warranty! Our team will quickly work with you to resolve any issues that you may have. |
04-04-2019, 09:18 AM | #10 |
Rep 383
My biggest concern is can there be a way that mufflers are seen to be there.
If a policeman pulled me over and looked under the car and saw no mufflers it would be a costly fine. I live in Australia. Catless DP's are harder to see when being pulled over. Surely I am not the first to mention the lack of visual mufflers? |
04-04-2019, 09:53 AM | #11 | |
Rep 300
-Mike |
04-09-2019, 03:55 PM | #12 |
Legend
49
Rep 127
Am I the only one that thinks that the burble tune sounds utterly ridiculous??? A couple of pops on a very high RPM off throttle sounds okay, but for it to be continuously popping at 3-5k rpms, with the flames coming out, is pretty rice-boyish to me!
We have a German luxury sports coupe in our 6-series. It's not a Lambo or a McLaren P1!....and it's not a Honda Civic Si with a 6" exhaust pipe! Maybe I'm in the minority here, but the other day I saw a BMW 335i with a burble tune drive down the street, and it started popping like crazy while decelerating at around 30mph. It sounded foolish! A bunch of teenagers that were nearby started laughing when they heard it. Personally, I would never want my car to sound that way! Outside of the burble tune, the muffler delete system from Soul sounds quite good IMHO. |
MMMM6GC275.00 |
04-10-2019, 02:41 PM | #13 | |
Rep 300
-Mike |
07-23-2019, 09:39 AM | #15 |
Rep 300
We can also do custom tips! Choose your color, choose your logo.
Custom logos / text is $50 for artwork setup fee and application. Coatings start at around $250 for either PVD coating or Jet-Hot ceramic coating with custom logo. Two color (different logo color) is possible through Jet-Hot but adds to the cost. Lead time is around 3-5 weeks from production to coating to your door. The PVD coater does OE exhaust applications and Jet-Jot, well, you probably know them! Their pricing isn't the cheapest but their quality certainly is. If you have any questions, let us know! -Mike |
08-21-2019, 03:09 PM | #18 |
Rep 300
Check out our latest Tech Talk blog post where we discuss PVD coating - what it is and why we use it to coat our tips!
-Mike |
06-25-2020, 12:19 PM | #22 |
Rep 300
In conjunction with a weld elimination in May, we're finally rolling out our cast Y section! This will yield better interior flow with the smooth wall path and edged interior. The thicker walls may yield a very slight increase in drone reduction.
We thank everyone for supporting us and in turn we'll continue to refine present and future products. -Mike |
