01-13-2019, 08:32 AM | #1 |
Rep 14
Left Car Running
I recently parked my 640i convertible, thought I had turning it off, got out. and locked it. When I came back an hour later, I found it was still running. I certainly felt dumb.
I think I had the auto start/stop turned off, but not sure. I don't think I will ever turn it off again, but there should be a timer to auto shut it down if running too long unattended |
01-13-2019, 04:38 PM | #2 | |
Rep 7,452
Or maybe the engine did shut down during the time you were away...but was starting back up as the battery voltage dropped...but then turned off when it recharged itself etc. ... but it just so happened to be running when you came back? From the owners manual below...gives info as to when the AS/S will not activate:
01-13-2019, 05:19 PM | #3 |
Rep 11
There's a coding option to make the horn beep if you lock the car (using the key fob) whilst the engine is running. Perhaps get it coded in if you think you'll do it again?
