08-11-2018, 03:56 PM | #1 |
Rep 140
640 gran coupe exhaust options
I used the search option, and couldnt find much info on exhaust systems for the 640i GC. Any suggestions as to what systems you guys are using pros and cons. I am only seeing Megan and eisenmann exhausts on youtube. Clips dont do either of them much justice. I am looking to do quad tips. And I have an msport 640 gc. Which diffuser is going to work with quad tips and my car? From my research I have come up with the m6 diffuser, am I correct or will a 650 gc diffuser work? Thanks in advance
08-13-2018, 08:45 AM | #3 |
Problem Solver
111
Rep 416
08-22-2018, 12:18 AM | #4 | |
Rep 19
08-22-2018, 12:20 AM | #5 |
Rep 19
Agreed. Sounds like he removed the exhaust and did a simple straight pipe. More pops come with a tune. I have the JB4 and it definitely helps and is easy to install if you're only doing stage1 for a conservative boost and not higher.
08-22-2018, 12:20 AM | #6 | ||
Rep 140
08-22-2018, 12:23 AM | #7 | |
Problem Solver
111
Rep 416
Straight pipe going to give you a lot of drone is the consensus from a lot of other senior members...
You need people like me so you can point your f*ckin' fingers and say, "That's the bad guy". "Das ist der Bösewicht". |
08-22-2018, 05:27 PM | #8 | ||
Rep 140
08-22-2018, 06:54 PM | #9 |
Rep 1,230
go m5 or m6 exhaust. Hpipe and delete resonators.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
08-22-2018, 07:02 PM | #10 |
Rep 140
08-25-2018, 05:14 PM | #11 | ||
Rep 140
08-26-2018, 11:02 PM | #12 |
Problem Solver
111
Rep 416
yes I have an xdrive and good muffler shop can do it..
08-27-2018, 12:31 PM | #13 |
Rep 153
I had a 640 GC xDrive and an exhaust (don't remember the manufacturer). If I could do it over, I'd stick with the M5/M6 exhaust and have a muffler shop install/modify as necessary.
'18 X5M | '17 650i Gran Coupe | '07 Tundra CrewMax 4x4 | '06 Lancer Evolution IX MR
09-09-2020, 05:37 PM | #14 |
Rep 30
I just had 2 borla mufflers and quad tips installed on my 640. I literally got nothing more out of it except drone at 2,000 rpm. I got them to agree to change it but I'm not sure what I should do.
1. Should I put stock resonator on for the right side, and delete left side muffler? 2. Delete them both? 3. Any combo of the above with an x pipe or H pipe. I'm not looking for anything crazy and definitely don't want drone |
