      12-06-2019, 11:16 AM   #1
drewdogg77
Drives: 2015 650i GC
2011 BMW 550I  [0.00]
Ac noise in cold temperature
My 650gc makes a motorized like noise whenever the temperature outside is cold through out the AC vents,, its not a watery sound its like a motor is trying to turn but stuck,, whenever the temp outside is about 73 degrees and below... Took it to the dealer and they drained out all the coolant and replaced it, they said its air in the cooling system but the noise is still there... any ideas what this could be????????
I have another appointment on tuesday 12/9/19 one of the techs said it could be the motor for the flap making the noise,, thing is they have to pull my whole dashboard out tho....
      12-06-2019, 01:17 PM   #2
Opie55
Drives: '15 650i Convertible
Too hard to say w/o being able to hear the noise. Not sure what "motorized" means, especially since you described a frozen motor as "watery."
      12-06-2019, 08:08 PM   #3
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
I'd put my money on the motor for the flaps. If you notice, every so number of times you turn off the car, these motors seem to go through a self diagnostics test, and they'll actuate for some period of time when the car is shut down. That's the only "mechanical" or "motor"-like sound I've ever heard come from the HVAC vents... not sure what else would even be located there to make such a sound.
Only other motor related to HVAC I could think of would be blower resistor motors - having had those go on a previous BMW, it didn't make any sound, though. The result of the failure was simply spinning up/down of the fan speed randomly.
I'm going with flaps.
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      12-06-2019, 10:32 PM   #4
drewdogg77
when the car is off i dont hear anything, its only when ac is on and the temperature outside is around 73 degrees and below, the bmw tech said only thing it could be is the flap motors but he doesnt look to sure lol,,, but they would have to pull my dash out to replace the flap motors,,, hmmm a little sceptical about that tho,,,,
      12-07-2019, 09:00 AM   #5
SanDiego640
SanDiego640's Avatar
Drives: 2016 BMW 640i Gran Coupe
On my E90 the blower motor exhibited similar noises when it reached the point of failure. I agree with the previous reply, I'm going with motor for the flaps or the blower motor.
Ron
2016 640i Gran Coupe M Sport/Glacier Silver (F06)
2006 325i/Graphite Grey (E90)
      12-07-2019, 09:59 AM   #6
thebmw
Post Advisor
thebmw's Avatar
1632
One of my 650s has a similar problem. When the heater is turned on (anything over 60 degrees on the temperature dial), it sounds like something is bubbling or an amplified water droplet sound. There is a rhythmic clunking as well that can even be felt in the steering wheel. I have cleared the cooling fluid lines and air bubbles. Although, someone suggested that there may still be a bubble stuck in one of the heating core valves. Others have suggested that a bearing in the heating core is bad. Not sure which one. Not worth the 10+ hours getting to the heating core to find out. I just turn on the heat to full, heat up the cabin, then turn it off.
