      09-07-2020, 09:34 PM   #199
cheeber
Drives: 10 Audi s5, 12 550i, 15 m4
many thanks. i was successful in updating 2012 f10, 2015 f83 and f82. worked great. on the fsc gen tool - noted that the 2021 maps were not listed in drop down, so selected 2020 - and the key worked.
      09-09-2020, 03:21 PM   #200
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [0.00]
Glad to hear but surprised the 2020 key worked unless you selected the lifetime code which would explain it.
      09-13-2020, 09:17 PM   #201
vihurricane
Drives: BMW 435i XDrive
Thumbs up Update Worked like a Charm
Thanks for instructions and the update files BadSeed . I was able to update to North America 2020-1. I'll update to 2021 next year.
BadSeed115.00
      09-23-2020, 11:41 AM   #202
mildbreeze
Drives: BMW 2016 528i
Thanks BadSeed for the 2021 NEXT maps. I updated my maps to the latest version with the FSC code.
BadSeed115.00
      09-23-2020, 11:15 PM   #203
Minacious
The Dovahkiin
Minacious's Avatar
Drives: M6 GC (Tuned)
I too want to say thank you. I finally took the time to sort out the FSC number as well as update the maps.
BadSeed115.00
      09-29-2020, 02:44 PM   #204
Kraftwerk AG
Kraftwerk AG's Avatar
Drives: Mein F Fünfundachtzig Einhorn
Shout out to BadSeed! Thanks for being valuable contributor to the forum and for your patience. Appreciate all your help.
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
― Jeremy Clarkson
BadSeed115.00
      10-16-2020, 04:03 PM   #205
dusek2
Drives: BMW X5
Unhappy incorrect map code
Hi, guys
I have successfully pulled the FSC file
Successfully generated map code
plugged in FAT32 usb and started the update
but when I input the map code it says it's incorrect.
Any ideas why would that be?
I tried both, Lifetime and not. same result.
Update
I tried installing 2020-1 map and it worked. Afterwords i updated to 2021-1 and it worked!!!!
      10-17-2020, 02:48 PM   #206
fabriciosc
Drives: BMW X3
Could anyone help me to get a fsc code? I downloaded the maps, but I'm not familiar with the code generation process, even looking at the extremely well detailed process from @badseed.
My vin 0S17917
Map Next North America 2021-1
I don't have ENET OBD cable. Appreciate if anyone can help with more details for a dummy. Thanks everyone!
      10-18-2020, 08:36 PM   #207
dusek2
Drives: BMW X5
BMWAiCoder 4.6
My vin 0S17917
If you dont have a USB slot in your glove box you will need ENET
Try out this app. Its really easy to use
BMWAiCoder 4.6
https://www.car-auto-repair.com/how-...or-navigation/
      10-23-2020, 05:03 PM   #208
ponytuning
Drives: '16 F16 50i, 15' F15 50i
Unable to download second file, when my connection drops mid-download or almost done it is unable to resume - happened 4 times already
      11-11-2020, 03:57 PM   #209
Aak
Drives: F31
Can someone help me with a link to EUROPE NEXT 2021-1?
(I have al lifetime code)
      01-13-2021, 12:22 PM   #210
meisser79
Drives: BMW X5 F15
I'd like the link as well please.
Thanks!
Does anybody ever put them on torrent sites? Piratebay or the like?
      01-23-2021, 09:59 AM   #211
TheShafro
Drives: 08 M3, 02 M5
Update prompt not showing up?
I have an NBT with 2016 maps on it and I'm trying to update it. I have a 32GB flash drive with 2020-1 maps loaded in it. When putting in this flash drive, the prompt popped up right away. But once I try the 2021-1 maps, nothing happens.
This is using the same exact flash drive, nothing changed but me deleting the 2020 maps and replacing it with the 2021 maps downloaded from here. I unzipped everything properly. Any idea why this is happening?
      01-25-2021, 06:42 PM   #212
seansimsneill
seansimsneill's Avatar
Drives: 2016 535I 2000 528I
2016 BMW 535I  [0.00]
How do we get the link for the new map update? I have the nbt evo
2016 535i
2001 530i
      02-15-2021, 11:47 AM   #213
LoveToyotas
Drives: BMW X3 XDrive 20D
How did you fix it?
Originally Posted by bobster2020 View Post
woohoo I fixed it.
Same as you, filesystem correct etc. but.....
I have the exact same problem.
How did you fix it?
      03-15-2021, 09:41 PM   #214
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
Drives: F06 M6
TY for the contribution!
2016 M6 Gran Coupe (Mine)
2013 550i M Sport (Mrs')
      03-30-2021, 07:08 PM   #215
deptrai1
Drives: BMW X5
Help please.
I downloaded the two sets of files onto a 32GB USB.
When I get to this step (part 5) , I fail...
1. Extract BMW_CIC_FSC_Generator.exe from the ZIP file
2. Open BMW_CIC_FSC_Generator.exe
3. Select OK to download Lookup.xml file (computer needs internet access)
4. Select OK then close and open the program again
5. Select NBT then use Browse button to select FSC file. I select CIC here (2013 X5), but where is this FSC file supposed to be located?
I’ve tried more than ten times in the last two days.
Where am I going wrong?
      04-20-2021, 04:02 PM   #216
teknodogg
I keep getting failed disk full message =/ am I doing something wrong?
my HDD is no where near full, can someone send me a fresh link to download the 2021 NA NEXT 1 and 2 map?
      05-01-2021, 08:13 AM   #217
BigJon88
Drives: BMW 340i
Would love the links to the maps and the FSC generator.
I have a NBT Evo system needing the Australia maps if that's possible.
Thanks in advance and love your work!
      05-24-2021, 09:44 PM   #218
xavier8288
Drives: BMW X3 2014 xDrive28i
Originally Posted by deptrai1 View Post
Help please.
You do need a FSC file. Please make sure you have ENET cable and follow the instruction clearly.
I just finish upgrading my F25 2015 tonight.
It also spent 1 hour to load the 2021 map
      06-04-2021, 03:16 PM   #219
unluky
unluky's Avatar
3603
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Thank you for this!
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
      06-18-2021, 10:07 PM   #220
wt888
Drives: none
Through trial and error, I found a solution why many USB drives don't work despite FAT32 formatting.
Many drives are seen by the PC as "Local Drive" in "My computer", as if they were backup hard drives, not portable memory sticks. After inserting
the USB drive into your car and getting a message to update it, an error message then says to insert the USB drive, and you can't get past it. The solution is actually to use a USB drive that is recognized as "USB Drive" in "My computer". If it shows up as Local Drive, your car won't see it as a USB drive either. The solution is to get another USB drive. I believe it has something to do with windows compliance standards, whether your memory stick shows up as USB Drive or Local Drive.
