      03-22-2021, 06:12 PM   #1
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
2001 BMW X5 4.4i with an oil leak
I’m not sure if it is coming from the VCG or the oil pan. I dont think it's the latter but ya never know. Any ideas?
It's got 94k miles on it.
      03-22-2021, 06:20 PM   #2
chassis
chassis's Avatar
6566
Drives: 9Y0 Cayenne S
Can you post more photos and some context? Is it your vehicle? Is the leak oil or another fluid (coolant, steering or transmission)?
Mosaud19983943.00
      03-22-2021, 06:25 PM   #3
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
Not my car.
I was looking to buy it for $1,400 and saw that. Looks to be one of the VCGs
      03-22-2021, 07:38 PM   #4
frchdragon
frchdragon's Avatar
338
Drives: 2016 BMW M4
I personally would absolutely stay away from anything BMW V8. I wouldn't touch them with a 10 ft pole. (except M stuff). If I remember well, they have issues with valve cover gaskets, oil separator, valley pan gasket and maybe timing chain guides.
Expensive maintenance cost, especially if the car isn't well maintained.
From the pictures, it is impossible to see where the oil is coming from, you need to look to see if there is oil seeping from below the valve cover.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD)
'85 635csi M30 turbo race car (SOLD)
Mosaud19983943.00
omasou2089.00
      03-22-2021, 07:45 PM   #5
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
Yup, I've heard BMW V8s suck ass. But, for $1,400 for a nearly mint X5. idk man
I was thinking about putting in some bottles of motor oil saver and seeing if that'll help the leak.
After all, I'm not keeping the car as a personal vehicle.
      03-22-2021, 09:02 PM   #6
chassis
chassis's Avatar
6566
$1,400 for a V8 X5? Run away.
      03-22-2021, 09:05 PM   #7
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
He was originally asking $2,900. I got him down to $1,400.
Either way, I don't think I want to spend more than $500 fixing it. It's a V8 BMW. Can't even get both of the VCG replaced for $500
      03-22-2021, 09:20 PM   #8
AnotherM
Cole
Drives: 2016 m5 CP
You have to remove the lower cover so that you can see where the oil is leaking from.
The m62tu very commonly leaks from the valve covers.
If you work on the car yourself, fixing that is very simple.
Mosaud19983943.00
      03-22-2021, 09:30 PM   #9
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
I've done the OFHG on the E46 my parents used to have.
Idk how easy a VCG would be on a V8 BMW though
      03-22-2021, 09:34 PM   #10
AnotherM
Cole
Drives: 2016 m5 CP
I've changed them on multiple e39 540i and they were simple.
      03-22-2021, 10:06 PM   #11
Mosaud1998
Mosaud1998's Avatar
2019 BMW 540  [0.00]
I think I'll watch a few videos before I pull the trigger
      03-22-2021, 10:30 PM   #12
Petro135
Drives: 2008 135i E88
2008 BMW 135i  [0.00]
Buy it
Mosaud19983943.00
Vivek.1367.50
      03-24-2021, 10:07 PM   #13
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
Drives: A Car
Avoid the V8 at all costs. My father had an E39 540i when new, and even back then with low miles that engine would have countless problems. BMW just doesn't have luck with their V8's. Find a nice BMW with the 2.5 or 3.0 M54 I6. Much more reliable, but will still leave a hole in your pocket, especially if you get the dreaded cooling system failure. They are out there, just hard to find. Found an original owner 05 E83 X3 for my youngest son with $15k of BMW Service Center receipts and was able to take it home for $3500. Took me over 10 different BMW's to look at, but finally was able to find a good one to replace his 323i. 25k miles later at 163k its had its Starter and Vanos Oil Line done, although the oil pan is leaking now, but overall running strong. *knocks on wood*
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300
Mosaud19983943.00
      03-24-2021, 11:17 PM   #14
whyzee125
Drives: Dinan stage 2 335i
Almost certainly both at that age. I wouldn't buy an older x5 v8 unless it's a 4.6is that's enthusiast owned. If you really want it, go for it, but just know it's going to cost a LOT to get it fully sorted.
Mosaud19983943.00
      03-25-2021, 06:56 PM   #15
AnotherM
Cole
Drives: 2016 m5 CP
If you cant work on a bmw yourself than dont buy an older one period.
If you can than buy it and enjoy.
Mosaud19983943.00
      03-25-2021, 10:07 PM   #16
Vivek.
Drives: 335is coupe, e30 vert
Or a 4.8is
Mosaud just buy it, keep it full of oil, and put $1400 worth of miles on it. Doesn't matter too much if it leaks oil, it's a $1400 X5 ¯\_(ツ)_/¯...invest in one of these for the driveway lol. Great winter beater. Cheap beaters are so underrated.
Originally Posted by relative4 View Post
My wife would give me so much head if I did that.
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6
whyzee1251680.00
Mosaud19983943.00
      03-27-2021, 02:00 PM   #17
JamesGames
JamesGames's Avatar
Drives: E60 550i|F82 M4|F48 X1|VA STi
Yea v8 bmws love to leak - on my 550i I've replaced
VCG x 2
Mechatronics seal on transmission pan x 2
upper timing cover x 2
lower timing cover x 1
alternator bracket seal (car pissed oil out was lucky motor survived after dumping two quarts in roughly 10 minutes. Carrying spare oil in the trunk of old BMWS is a must)
Currently leaking oil at the oil pan drain bolt area - need a new oil pan but it's a slow drip.
Car has 125k - 2007 550i
Mosaud19983943.00
      03-27-2021, 04:49 PM   #18
thebmw
Post Advisor
thebmw's Avatar
1634
OP, I'm in Chicago and I'm selling a 2014 X5 50i xDrive in Great Condition for only $7K (plus what I spent on repairs and 5 yr/160K mile warranty last year which was $21K total). It's a heck of a deal IMO as it will last for another 75K miles I'm sure.
With BMWs and their V8s, you have to "pay to play". If you want a smaller, less powerful, less melodic engine, it will cost less. Personally, I own 4 BMW 4.4L twin turbo V8s. I think they are fine overall.
      11-22-2021, 04:23 PM   #19
cvstar9M3
cvstar9M3's Avatar
Drives: 2011 MR e90ZCP 6-MT
Still got this?
2011 MR e90ZCP, 6-mt
2011.75 e90 M3 ZCP, DCT, ZP2, ZCV, JB w/ 2Toned FoxRed/Black Interior - SOLD
      11-22-2021, 04:25 PM   #20
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Front timing change gaskets. BTDT.
Like the other frchdragon mentioned stay away from any high mileage BMW V8 they are a money pit or can burn as much as 1 QT every 1K. His list is pretty spot on.
Talked to a guy at the barber shop who carried a case of oil in his trunk!
