      03-22-2021, 10:49 AM   #1
A51F640d
Drives: 640d Gran Coupe
Alloy Wheel fitment
Hi
I have 640d gran coupe, and was wondering if these alloy wheels will fit and how much the rears would stick out.
I only thought about the offset after I had purchased them
Front 9J ET20
Rear 10.5J ET25
If any one has similar setup, pictures will be appreciated
Thanks
      03-22-2021, 04:49 PM   #2
Parksie11
Drives: BMW 650i Coupe. 2015
Ouch, These are going to be no good for your car!!!
My own wheels are Front 9J Et 35 &. Rear 10.5J ET42 & fit perfectly, your new wheels will poke out a minimum 10mm Front & 18/20 mm Rear??
      03-23-2021, 11:26 AM   #3
jjasonSU
Drives: 650i, NSX
The fronts will be aggressive but can work.
The rear offset is too low. For a 10.5 wheel you need the offset to be between +35 and +40
      03-23-2021, 03:38 PM   #4
sixfiftyay
Drives: 2013 Bmw 650I Gran Coupe
Originally Posted by A51F640d View Post
Hi
Front 9J ET20
Rear 10.5J ET25
Thanks
fronts will be perfectly fine. they will fit flush on the fender with no rubbing. that's what i run and even lowered on h&r springs with a 255 tire, i never rub.
the rears will poke out. you can run a stretched tire and camber it a bit to get it to fit but it's going to have some poke to it. +30 is the absolute lowest i would go with a 10.5" wheel in the rear.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
