      04-01-2020, 02:22 PM   #23
Taheemr
280
Drives: M6 GC
Originally Posted by BLACK KILLER View Post
another picture on the side
What lowerng springs did you fit KW and whats the drop in height ??
Thanks
      04-01-2020, 03:55 PM   #24
mikerx5
mikerx5's Avatar
461
Drives: 2014 F06, 2022 G06
Goodness! What make were the spacers?
      04-01-2020, 03:58 PM   #25
BLACK KILLER
BLACK KILLER's Avatar
Germany
90
Drives: BMW'16 M6GC
Thanks
These were KW springs and the real drop was 30mm (max) in front and 30mm in the rear axle.
      04-01-2020, 04:26 PM   #26
benacto
benacto's Avatar
348
Drives: 2016 Singapore Grey M6 GC
Originally Posted by AlpineKing_M6GC View Post
Thanks bud! Sticking to stock suspension for now, these city roads are like driving on mini land mine ruts! I think I'll go 10f-12r setup and hope that the front's don't vibrate at speed.
just chiming in on the spacers... I tried 2 different sizes from 3 different and most popular companies... no matter what I tried, anytime with spacers in the front, I'd get steering vibration at around 70+mph.
So i left the rears on and just took the fronts off. Look wise, the fronts actually doesn't need em.
      04-01-2020, 04:30 PM   #27
mikerx5
mikerx5's Avatar
461
What size rears did you go with? Not a bad idea on rears only
      04-01-2020, 04:39 PM   #28
BLACK KILLER
Germany
90
Drives: BMW'16 M6GC
H&R
      04-02-2020, 10:17 AM   #29
AlpineKing
Drives: 2018 M6 GC
Yep, this is what I've heard as well. Hence has been my delay.
question: it appears that the wheel vibration would be due to an imbalance to the rim & spacer that is shown at higher speed. Would rebalancing the wheel accounting for the additional spacer weight resolve this? Unsure how the tire balancer would be able to account for it though as they are two separate pieces.
      04-06-2020, 12:01 PM   #30
benacto
benacto's Avatar
348
i tried 12mm first... then I ended with 10mm. they fit perfectly flushed. and when I will go 305 on the rears... they won't look like a monster truck.
      04-06-2020, 12:06 PM   #31
benacto
benacto's Avatar
348
I don't know.. I had tried to get it balanced multi times. I tried scrubbing and cleaning the hub of all rust, and dirt.. tried different brands of spacers everything i read that could possibly fix the vibration.
And at the end... the answer I get from many members and shops are the same "With spacers, you're just gonna have a little bit of shake at some point at high speed."
      04-06-2020, 12:25 PM   #32
mikerx5
mikerx5's Avatar
461
Got it. Would love to see a pic when you get a chance.
      04-08-2020, 03:29 PM   #33
benacto
benacto's Avatar
348
you can kinda see the stance ... stock suspension.
      04-08-2020, 05:03 PM   #34
mikerx5
mikerx5's Avatar
461
Looks fantastic
      04-09-2020, 01:34 PM   #35
benacto
benacto's Avatar
348
Looks fantastic
thanks. I think that works for me.
      04-09-2020, 07:03 PM   #36
AlpineKing
Drives: 2018 M6 GC
Looking good! Working on getting a set of 10mm for the rears to start. Let's see how it looks prior to the fronts. Now to get someone to install during the madness of COVID
      04-09-2020, 07:46 PM   #37
mikerx5
mikerx5's Avatar
461
Im starting to look also, let me know what you end up with. Maybe a dumb question, but do they need longer bolts
      04-09-2020, 09:40 PM   #38
AlpineKing
Drives: 2018 M6 GC
Yep they do, the good ones come with them
      04-10-2020, 12:50 PM   #39
benacto
benacto's Avatar
348
all of mine came with longer bolts. and you don't need anyone to "install" them. you just take the wheel off and put them on.
      04-10-2020, 01:09 PM   #40
RagtagXMASTER
RagtagXMASTER's Avatar
119
Drives: 2013 M6
which brand is best to go with for long lasting quality hopefully. I would like a set of 10 and 12 mm spacers and bolts
      04-10-2020, 01:12 PM   #41
AlpineKing
Drives: 2018 M6 GC
For sure don't "need" anyone to install them, but current living situation doesn't have me in proximity to tools/jack/lift.
      04-10-2020, 02:00 PM   #42
mikerx5
mikerx5's Avatar
461
Seems like the macht schnell are popular, im looking also.
      04-10-2020, 02:17 PM   #43
Petepacman
Drives: BMW M6 Gran Coupe
I have BMS spacers 10mm up front and 12mm rears. I have never had any vibration and have been running them for almost a year. They came with extended lugs as well
      04-10-2020, 06:56 PM   #44
benacto
benacto's Avatar
348
that's right... I don't think my M6 comes with a little jack kit.
