10-08-2020, 04:34 PM | #1 |
Rep 4
640D Gran Coupe LCI Parking Sensor Issue
Hey all.
My PDC system has recently gone completely beserk and keeps springing up issues about not being able to work. The rears are fine, however I have identified one particular sensor at the front end. It does however trip out the whole system. I have seen that all sensors apart from just that particular one work. Everytime I try to use the surround view camera system, the whole system just switches off and continually springs warnings that make it an all together frustrating experience. My question is, would 1 faulty sensor cause the whole PDC system to bug out? It does work sometimes, and other days it doesn't, very tempremental. Also, how easy is it to replace the sensor? Do I just take off the bumper and it's a plug and play part or? I've managed to source a replacement original BMW sensor. Thanks for your help. |
10-08-2020, 05:36 PM | #2 | |
Rep 2,902
10-08-2020, 05:49 PM | #3 | |
Rep 4
10-09-2020, 10:58 AM | #4 |
Rep 2,902
Surround view cameras are easy. Once you remove enough fender liner bolts to pull them back, each camera is held in by two pretty small torx screws. You remove the screws and the cameras just slide straight out. Then just let them hang there by the wire. No need to take them fully off.
10-09-2020, 05:56 PM | #5 | |
Rep 4
