04-21-2019, 02:17 PM | #89 |
David
786
Rep 2,009
I use 5W-30 Pennzoil Euro-L, one of the few oils I can easily get with BMW LL-04 for my diesel engine, pair it with a Mahle filter
I buy the Mahle filters off rock-auto $11/each and the oil from Walmart online, it's like $22/5 quart I also buy two oil changes at a time to get the free shipping off Walmart's website I do 5k mile OCI, at 5k I do it myself, when I hit 10k on the CBS I take it into the dealership for the free change. They do use 0W-30 but don't think it hurts to switch back and forth. |
04-21-2019, 02:20 PM | #90 |
Rep 3,726
Another thing to keep in mind is if you run E85, you need to change your oil more frequently.
Based on oil analysis, I lost 2500 miles (from 7500 to 5000) of TBN retention using Redline oil. No more extended OCI for me.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
05-26-2019, 06:37 PM | #92 |
Rep 9,032
What weight oil are you guys getting?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
10-16-2019, 09:36 PM | #93 |
Rep 1
I got a new N63 engine under the Bang Class action and noticed the first fill was LL12 FE. I asked the dealer and was informed this is the new standard across the board (even through all posts say it's Diesel only for single turbo). Given issues I had with valve stem seals on old engine with LL01 high SAPS oil, I am going to keep using LL12 0W30 Fuchs brand and change the oil myself every 5K miles. No oil consumption, better gas mileage by at least 1 mile/gallon albeit a new engine. Low TBN (~8.9) should be OK if I'm changing every 5K.
10-23-2019, 09:43 AM | #94 |
Rep 8
10-25-2019, 07:54 PM | #95 |
Rep 87
Piggybacking off this thread, anyone know why my CBS might suddenly go from 10K intervals to 5K? Changed it at 8K, 16K, 26K, 36K (maintenance reminder came on each time). At 39K it still said some 8K miles to go, then suddenly I was overdue by 30 miles at 41K (no countdown). 80%+ highway miles. Quite a few on this thread seem to be doing 5K OCI but it seems excessive for this usage and very weird how it suddenly went to this interval
(Other thread https://www.2addicts.com/forums/show...php?p=25386169) |
10-25-2019, 08:16 PM | #96 | |
Rep 6,863
10-26-2019, 02:31 AM | #97 |
Rep 87
Yes, it was specifically oil change which I did less than 5K ago along with brake fluid, which is why I was so shocked. Used the oil level checker function and it was also full.
11-12-2019, 06:46 PM | #99 |
Rep 28
I've been using Pennzoil 5w 30 euro L but want to switch to 0w 30. Liqui Molly seems to be a good choice but which particular formula should I go with ?
2011 X3 28i |
11-12-2019, 07:52 PM | #100 |
Rep 4,145
Drives: '18 M2 6MT
I use whatever the dealer puts in it, but I could probably use cooking oil since I don't drive my car hard at all.
11-12-2019, 09:20 PM | #101 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
5w-30 Pentosin, use Mobil 5w-30 "High Mileage" for topping off when it's low.
Thinking about switching to Liquid Moly 5w-40, maybe the Molygen.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
11-13-2019, 08:52 AM | #102 |
Rep 6,863
pennsiveguy3552.00 D3GUY0.00 |
11-13-2019, 09:04 AM | #103 |
Rep 3,004
I prefer....
....the white truffle oil with a hint of rosemary aroma.
Racerbruce
///M Power-Belgium63410.50 |
11-13-2019, 12:22 PM | #104 |
Rep 4,145
Drives: '18 M2 6MT
11-13-2019, 01:34 PM | #106 |
Rep 3,550
Just put Castrol 0W-40 in both my cars.
It used to be good enough for BMW, but it's still good enough for Audi, VW, MB, Porsche... Pretty sure I'll be fine. |
11-14-2019, 02:01 PM | #109 |
Rep 3,726
So annoying that the Pennzoil isn't widely available
11-14-2019, 02:43 PM | #110 |
Rep 6,290
Where are you that you can't get it?
My 0W-40 German Castrol is actually being phased out of the BMW LL01 in Canada. I know LL01 isn't really a requirement some say but I just found that curious and was the main reason why I decided to switch. |
