04-23-2019, 08:13 AM | #4 |
Rep 7,484
Do a search for the BimmerCode app. As mentioned above, this can be coded using aftermarket software.
04-25-2019, 03:23 AM | #5 |
Rep 1,825
Minimum requirement for factory coding is that you have comfort access (ie, lock and unlock by touching the door handle). Without this the coding cannot be done (stand to be corrected if anyone can prove the contrary).
Beyond that something like a SmartTop module would be your next option. |
04-26-2019, 09:49 AM | #8 |
Rep 7,484
You connect the app (that you download on your device) to your car with an adapter that plugs into your OBD II connector.
See videos below (randomly chosen using a google search) for an example of how it is done:
04-26-2019, 01:17 PM | #9 |
Rep 279
That is amazing. I never knew you could do that.
I saw the word coding and thought I had to work at Microsoft to get these things done.. Thanks so much! |
04-28-2019, 06:29 AM | #11 | |
Rep 7,484
See examples below...I looked into the FEM (front electronics module) to see what coding is available...and AMBIENT LIGHTING is right at the top...if you click on it...you will see that you can change the ambient lighting in percentage amounts (see screen capture/pics below). I didn't search for color change...but there are coding forums that would definitely know if it is possible if you can't find it.
04-29-2019, 09:16 PM | #12 |
Rep 279
Thanks so much for the above information.
- What is the the Ambient lighting brightness setting default before coding? - Is the "Vgate iCar Pro BLE 4.0" the best one to get? Last edited by MichaelInChicago; 04-30-2019 at 05:55 AM.. |
