      06-03-2021, 04:05 PM   #1
tom4814@aol.com
New Toy for the Sun
Drives: 2015 BMW 650I X drive Conv
2015 650i Exhaust Tip Replace
Previous Owner Crunched the driver side exhaust tip.
Help, I need ideas on fixing or replacing the tip. No other damage to exhaust.
Dealer says Integrated into exhaust system so replace entire system on that side, I said ouch to $2800. The exhaust Pipe is really strong/hard.
So: 1. Grind / Cut both tips off and replace with something else
2. Grind / Cut out part of both pipes so look the same
3. Find a pipe bender to straighten out the one
4. ???
I'm open.
BTW I also have a new diffuser to replace the scratched one in the pic but plan to do everything at once.
      06-03-2021, 05:01 PM   #2
doggboy
Drives: BMW 650i
Where are you located? I have a set of stock m-sport mufflers and m-sport diffuser i dont need.
Or you can do this...
https://www.6post.com/forums/showthread.php?t=1317986
      06-03-2021, 06:00 PM   #3
tom4814@aol.com
New Toy for the Sun
2015 650i Exhaust Tips
I'm in Breckenridge CO and part time in Denver CO. I see you are in San Diego.
      06-03-2021, 06:02 PM   #4
tom4814@aol.com
New Toy for the Sun
I already have a new diffuser.
Maybe a really good grinder or metal cutter will make the process easier?
Thanks
      06-03-2021, 06:27 PM   #5
doggboy
Drives: BMW 650i
If i were going to cut the stock tips off, i would use a multi tool. They work amazingly well and can get into tight spaces.
      06-05-2021, 08:15 AM   #6
AccordTR
AccordTR's Avatar
4. ???
I'm open.
Cut them off and put quads on. The stock ones look too tame.
M Sports Edition
Carbon Wing
Carbon Front Splitters
Carbon Rear Diffuser
Carbon Grilles
CPG intakes
Arm catless downpipes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-05-2021, 09:31 AM   #7
jjasonSU
Drives: 650i, NSX
Yeah man been there. See if they will order u one. It's $850. Had to be ordered from Germany.
Pic of my car with bumper removed
https://www.ecstuning.com/b-genuine-...t/18307629137/
      06-05-2021, 07:44 PM   #8
skilz4u2nv
Drives: 2014 BMW 650xi
Nice! my post finally might have come in handy for someone!
If you really like that look then the other poster on here was right, they are a pretty expensive piece to replace and a bear to take off neatly.
If you are indifferent and dont mind a different look then I would shop them out and put new tips on.
      06-08-2021, 12:59 PM   #9
e38740imd
Drives: 2016 640i
Ive seen the tip alone being sole online somewhere. i would cut the old one and weld a another one. not sure if it was black. but 80 bucks to powdercoat is a no brainer
