11-24-2018, 02:51 AM | #1 |
Rep 8
Drives: 2014 M6 Gran Coupe
Squeaky Brakes
2014 M6 GC, 34,000 mls, squeaking brakes, brakes pads have 70% left all around, I am new to BP, is this normal?
JR
11-24-2018, 03:39 AM | #2 | |
Rep 1,996
high performance brakes in general tend to squeal a lot. the carbon ceramics on my car are very noisy. my M3s never made much noise unless I had track pads on in which case it sounded like a dump truck coming to a stop. if you're sure there is enough pad left, I don't think* there's much to be concerned about. that said, if you're concerned, never hurts to have it looked at by a professional who can lay eyes/ears on the car. welcome to the forum.
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
jahkuma4.50 |
11-24-2018, 07:36 AM | #3 |
Rep 8
Carbon Ceramic, and thank you
JR
11-24-2018, 01:18 PM | #4 |
Rep 123
My CCBs squeal a little bit under light braking, but goes away for a few days after pressure washing the disks and calipers. If I don't pressure wash at each washing, it can get pretty loud. Pressure washers are probably the best thing that happened to mankind.
11-24-2018, 05:15 PM | #6 |
Rep 8
Ok, had brakes evaluated at my Local Dealership, tech said as you all have said this is normal for high performance brakes, I tried bedding, worked for month then retro. Car is driven approx two to three hundred miles per month, not sure if this is a contributing factor.
Will try pressure washing. Thanks all !
JR
11-25-2018, 10:58 AM | #7 |
Rep 12
Can confirm ccb = squeaky. Support group should be formed.
evanescent031029.00 |
11-25-2018, 10:24 PM | #8 | |
Rep 1,996
11-26-2018, 01:24 AM | #9 |
Rep 8
I figured, I plan to do so
JR
11-26-2018, 08:46 PM | #10 |
Rep 582
I have CCBs also , mine are quiet, but I also pressure wash my car when I clean it , I use Adams car shampoo in a foam cannon then use a soft brush on the wheels , the wheels are never dirty with brake dust so cleaning with regular soap is all that’s needed
11-28-2018, 02:00 AM | #11 |
Rep 60
same issue with my non CCB, I need to bed it again by doing a few hot brakes then it goes away for a while then comes back. Usually worse on dry days. Maybe i should apply some copper paste or something on the backing plate but im too lazy nowadays.. just a few hot brakes and it goes away.
11-28-2018, 07:22 PM | #12 |
Rep 8
Sounds good, will pressure wash next go around, they have quieted down now the weather is cooler.
JR
11-28-2018, 07:41 PM | #13 |
Rep 582
Yeah , pressure wash the $hit out of each rotor use a 40 degree tip, hit the pads a caliper really good it blows all the residual dust left behind that causes the squeaking, if you look in the manual on your idrive it actually tells you this procedure for CCB brakes.
11-28-2018, 07:48 PM | #14 |
Rep 8
Got it will do and many thanks!
Will update you
JR
12-11-2018, 02:36 PM | #15 |
Rep 217
You can also try some of this.
https://f10.m5post.com/forums/showthread.php?t=957348
'14 F10 CP M5 AW/Full Sakhir Orange, Gloss Black 343Ms, Black IND Cosmetic Package, M Performance CF Diffuser and Spoiler. - SOLD
