      02-22-2021, 05:28 AM   #1
Ahad
Drives: BMW 640d Gran Coupe
NBT EVO Retrofit
Hi anybody know a list of what parts I need to complete a retrofit with apple car play etc.
      02-22-2021, 11:25 AM   #2
hugo_nz
hugo_nz's Avatar
3184
2022 BMW IX  [0.00]
This topic has been covered ad nauseam so a forum search should really be your first stop. The year of manufacture and current equipment fitted dictate what can and cannot be done.
In short if you have CIC you will need: head unit, screen, idrive controller, new radio antenna amp, new audio amp, possibly a new ZGW module, some wiring modifications, control module coding. Very Expensive option.
If you have NBT you will need head unit, screen, possibly an ATM module, coding to unlock carplay, control module coding. Expensive option.
Just buy an MMI module to enable car play on your existing idrive. They are a dime a dozen nowadays, pretty much all from the same hardware manufacturer, and can be installed in under 30 minutes with no modifications to the car.
      02-22-2021, 03:38 PM   #3
Mnfamilyguy2020
Drives: 2020 X4MC 2018 RR
+1 on the MMI or UNICHIP. Once you go CARPLAY or the Android equivalent the integration of mobile tech to your smart phone makes cic/nbt/evo irrelevant. But, with the press of a button that BMW system is still all there to be used at any time.
All the Manufacturers are now building their enter/infotainment systems around android auto and CarPlay.
hugo_nz3183.50
Tags
nbt evo, sat nav
