12-05-2018, 03:57 PM | #45 | |
Rep 909
I believe so too and for the V8 I think Stage1 gives plenty of power to begin with. On my F32 the OTS map (Stage 2 in that case) has not caused me any issues. In both cases I think the OTS maps are pretty proven considering the people at PTF and/or whoever may write them have plenty of experience. |
FSociety3811.50 |
12-05-2018, 06:08 PM | #46 | |
IG @bmwF9xG80
3812
Rep 7,592
Drives: G80 M3, X4M, G07 X7m50
Personal friend running E30 OTS (S55) for a full year on stock hardware not a single hiccup with 30k+ miles on the tune. So far 6k miles in my new S55 I wish I found a N63TU a few months ago as that was my first choice of car I wanted to get.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
FBMWWINS603.50 |
12-06-2018, 04:15 PM | #47 | |
Rep 909
As for the PLUGS I will drive OEM a little longer as mentioned but I have already checked based on what @Cmb6s stated in his post further up. The choice will be between: 1) NGK 97506 SILZKBR8D8S LASER IRIDIUM These are apparently one heat range colder than the standard Bosch plugs found on the 650i. The NGK listed as part number 12120039664 are actually standard on the ALPINA B6 model. 2) ORIGINAL BOSCH ZMR5TPP330 from M models car (M2-M6) The Bosch ones mounted on several M cars are supposedly 2 heat ranges colder. Still I love NGK and I find it hard after the positive experience on the F32 to go back to Bosch. |
FSociety3811.50 |
12-06-2018, 08:25 PM | #48 |
Rep 21
Thanks F06WINS. Those are exactly the two plugs that I was referring to. There was an NGK article stating that if you add about 75-100hp over stock, it’s probably worthwhile to go 1 step colder. Thus, my inclination towards the NGKs. If you’re up in the high 500 range (like the M6), then it might be worthwhile to consider those Bosch plugs. Essentially for a stage 1 OTS bootmod3 tune (which is what I’m doing), I think either the stock plus or the NGKs will be fine. I ordered some NGKs just because I bought my car used and figured I’d like to put new plugs in anyway.
Just as an FYI, I decided to flash my car today anyway and everything went smoothly. The power is definitely noticeable, though I haven’t had much of an opportunity to test it. It does seem like the engine is moving a little more on the mounts after the flash. Don’t know if that’s a result of just having increased power or something else, but it’s a pretty minor variation... just something I noticed. I still hope to dyno next week, but will probably try to do the OTS flash first and then go back to stock for another run to have the comparison. Wanted to make sure I could flash it so that I could maximize my hour on the Dyno. |
12-07-2018, 01:36 AM | #49 |
Rep 909
Thanks a lot for sharing too. I'm curious to hear your results. Same as i mentioned above I have not been able to test the BM3 that much either but the tune is noticeable and whether it's 80, 90 or 100 HP gain, it is certainly a great tune for a Stage 1. I had a chance to speak to one of the people yesterday at PTF and they advising the following:
"If you'll be running less than 25psi of boost we suggest a 0.020" gap, or 0.018" if planning to go higher. In most cases though we just go with the 0.018" gap and call it a day. We don't suggest using the S55 OEM plugs when tuning your motors and the NGK SILZKBR8D8S (97506) have been found to be far better." Not only based on their feedback, but as I was saying my experience with NGK and tuned engines (back since the N54, N55 days) has been fantastic. Thus I will opt for the NGK ones mentioned above. |
12-07-2018, 03:44 PM | #50 | |
Rep 301
Drives: 2017 BMW X5M
12-19-2018, 09:17 PM | #52 | |
Rep 206
12-19-2018, 10:28 PM | #53 |
Rep 21
I have not had any misfires with the OEM plugs thus far. When it warms up a little, I’ll probably replace with the NGKs regardless... just because I think it’s better to run plugs than are too cold vs too hot.
Also, as a data point for others, I did finally manage to get the car on a dyno. Unfortunately, it took so long to get the car sorted out and put it into “roller mode” that I didn’t get a chance to do a baseline run. In the end, I was extremely pleased with the results. The power band looked nice and level over a wide range of rpms. The fuel/air ratio looked good throughout and the dyno operator told me that it looked perfect at the high end of the rev range (around 11.7 if I remember correctly). The peak power number was 487 rwhp and all three runs were extremely consistent. Literally within about 2 hp of each other. I was pretty surprised with the number, but it was on a Dyno Jet and I don’t have a baseline for comparison, so it’s not really that meaningful. Still... it had me grinning from ear to ear when I walked out. The other thing that had me grinning was listening to the M sport exhaust with valves fully open at full chat. I still think it’s pretty quiet and subdued 98% of the time, but when you get on it in the upper rpm range, man does it sound good. |
12-20-2018, 02:03 PM | #54 |
IG @bmwF9xG80
3812
Rep 7,592
Your car is 2013? Then probably had plugs as they widen with time.
05-16-2020, 03:15 PM | #55 | |
Rep 289
If I purchase a used BM3 license from someone who say had it on a single DME car, I will have to pay an upgrade fee to use it on my N63TU? Also, say when a license is transferred, does the new user get to choose any 1 OTS Map? Or whichever free map was on the license before gets transferred? I know that purchased maps or bundles do NOT get transferred. |
05-16-2020, 05:14 PM | #56 | ||
Rep 285
05-16-2020, 08:14 PM | #57 | |||
Rep 289
