11-13-2020, 07:57 PM | #1 |
The Dovahkiin
312
Rep 147
A knock has reared its ugly head.
Well, this started yesterday.
The car is a 2016 GC with 42k on the clock. An oil/filter change (Liqui Moly Molygen 5W40) was performed a few hundred miles ago, and a Spark Plug (NGK 97506 gapped to .20) change a few hundred before that. All was well until yesterday when moving slowly in traffic; nothing aggressive, just coasting along at 15mph. I tried to capture the sound in this video hoping for some insight from the more well-versed of you on this engine. You can hear me give some light throttle to see if the noise increases with the RPMs. It doesn't appear to, but I might be wrong. Thanks in advance. |
11-13-2020, 10:46 PM | #2 |
Fueled by Recycled Dinosaurs!
623
Rep 1,162
Drives: F06 M6
Sorry to hear about the issue. Are you running a tune or using an external boost controller? Mine was stock and had rod bearings done at about the same mileage and ended up seizing about 30k miles later on the new bearings. The car was dealer maintained and not once did they ever say anything about metal in the oil. I learned a lot about this issue after taking my wife out to dinner one night. I would go easy on it until you get a firm diag.
I may be a bit hypersensitive or over reacting because I went through this a few months ago but it sounds like a rod bearing issue. Send a copy of the video to Mike and/or Raza at RKAutowerks, they have a ton of experience with these engines and are not going to mislead you just to get the business because they already have plenty of business.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vision, CCB, RKAutowerks Forged Rods/Pistons & E85 DI Exhaust Cams,Carbon Fiber CAI & Billet Diff Brace, Infinity Design CF Turbo Inlets, Swaintech Coated DPs, Mishimoto Oil Cooler, JB4, XHP S3 Flash, Bootmod3
Minacious312.00 |
11-13-2020, 11:00 PM | #3 |
623
Rep 1,162
Drives: F06 M6
A thread from the M5 folks, https://f10.m5post.com/forums/showthread.php?t=1395678
If you want to chat about my experience or want contact info for the team at RKAutowerks shoot me a PM. Wishing ya much success.
11-13-2020, 11:03 PM | #4 |
623
Rep 1,162
Drives: F06 M6
Another data point from a fellow M6 owner, https://www.6post.com/forums/showthread.php?t=1743012
11-14-2020, 09:24 PM | #5 |
Rep 51
At least speak to Mike at RK Autowerks. I just went through a rebuild with them and couldn't be happier. It's only been about three weeks but the car runs amazing. They are phenomenal at what they do. In my case the rod bearings were worn out. I had metal in the oil even though I had just changed the oil. If you also wanted to get me personal experience with them feel free to PM me. TinCan Sailor also was the one who gave me some valuable advice. Good Luck!
TinCanSailor622.50 Minacious312.00 |
11-14-2020, 10:36 PM | #6 | |||
The Dovahkiin
312
Rep 147
Appreciate the replies. Both of your threads I actually read before this happened, so I am familiar with your journeys.
It will remain parked in the garage until a solution is decided on. Quote:
RK is in Texas, correct? It's looking like the end of 2020 is going to get a little expensive. Stay tuned. |
TinCanSailor622.50 |
11-15-2020, 08:24 AM | #7 |
Rep 582
Get an oil analysis done also these cars have a lot of cilickity clacking going on , did you ever open your oil cap while the car is running wow ?
11-15-2020, 11:38 AM | #8 | |
623
Rep 1,162
Drives: F06 M6
11-15-2020, 11:42 AM | #9 |
623
Rep 1,162
Drives: F06 M6
True, a Blackstone Labs analysis is a nice low-cost way to get another data point on what is going on.
11-15-2020, 01:11 PM | #10 | ||
The Dovahkiin
312
Rep 147
If I do end up going with RK, it will end up in their possession, as I prefer the shop doing the work to also do the install. |
11-15-2020, 01:44 PM | #11 | |
623
Rep 1,162
Drives: F06 M6
11-15-2020, 02:03 PM | #12 | |
The Dovahkiin
312
Rep 147
I did want a bit more volume from the exhaust, turbos and intake, but was content, for now at least, with the car. That contentment may change now if the car has to end up in the hands of a shop to get sorted out. That 2 yr warranty with RK? |
11-15-2020, 02:14 PM | #13 | |
623
Rep 1,162
Drives: F06 M6
I am with you on the exhaust sound, it really needs a throatier sound. I am not looking to make old people faint but if the neighbors kids thought monsters were under the bed when I start it would be ok
11-15-2020, 09:44 PM | #14 |
Rep 51
I am with you guys regarding an exhaust. It needs to roar more. But looking at some such as FI exhaust or Akropovic?? All are very expensive into 4K and up.
11-16-2020, 12:59 AM | #16 |
The Dovahkiin
312
Rep 147
11-21-2020, 09:09 PM | #18 |
Rep 90
I could be totally wrong but this really sounds like a bad pulley. Remove both front mounted intercoolers and check all your belts, tensioners and pulleys.
Im hoping for the best for you and the beast, fingers crossed that is that case, please keep us posted. |
03-05-2021, 09:37 PM | #19 | |
The Dovahkiin
312
Rep 147
Bullet points of what's been going on:
Now I just need to figure out the logistics and how far I want to go. I work 10-12 hours a day building fictional worlds, and as such, my time is painfully limited, but I will do my best to chronicle my journey once it begins proper. Stay tuned. |
