      12-17-2018, 03:29 PM   #23
brad850csi
Drives: 16 F13 M6 Comp
I went with 305s and I'm looking at the rear now thinking a 10mm spacer could still work
      12-17-2018, 07:15 PM   #24
xxTHIR13ENxx
Drives: M6 Gran Coupe
Originally Posted by Flo1989 View Post
Yup - that's going to be a nice set up. If I were to ever run spacers in the front I'd go with 10mm also. Do you have a competition pack car? If so, they're lower than the non comp cars by like .25" inch I believe.
Yes, I do. That might be it, then.
Either way, I'll see how it looks with the spacers first and decide on what drop to go with afterwards (if at all).
Figured I'd start with the smallest price-tag and work my way up. lol.
      01-04-2019, 10:45 AM   #25
xxTHIR13ENxx
Ok, something's not adding up...
Here's the rear with 12mm spacer installed, stock suspension.
As you can see, there's still a significant tuck going on. I measured the wheel and it's 10.5" (OEM spec). Tires are also OEM at 295.
Could there be something else affecting the fitment? I'd hate to have to go 20mm+ spacer. Any advice on what else to look for/consider would be greatly appreciated.
Installed 10mm in the fronts and they're perfect (sorry, no pic).
Thanks for all the input and help.
Leo.
      01-04-2019, 01:20 PM   #26
frozenM6
Drives: BMW M6 CP
Originally Posted by 352M6GranCoupe View Post
I’ve been searching for quite some time and wanted to see what setup I should go with on my M6 Grancoupe competition package. I see a lot of people end up going with 10F/10R, 12F/10R, or 12F/10R... after looking at my car from various angles I was thinking of going 10F/12R. Maybe I’m crazy but the 601 rear wheel on my Grancoupe seems more tucked in when compared to the front. Does anyone have a pic of ther M6 GC with 10F/12R???
Thanks in advance!
2015 competition
No rubbing and aggressive stance. Spacers were use for 2months just siting on shelf now. . Anyone interested let me know. Selling for cheap. Will check for the size forgot off hand what they were.
      01-04-2019, 02:03 PM   #27
brad850csi
Leo.
What is stamped on the back of the wheel? I’m guessing it is a 34mm F10 wheel, not a 19mm M6 wheel
      01-04-2019, 02:49 PM   #28
xxTHIR13ENxx
I think you're right on; not sure on the "real-life" offset, but this is a second-hand car with known wheel repairs, so very possible that the wheels were swapped out at some point.
With that being said, wouldn't the higher offset cause issues with the suspension? Wouldn't there be rubbing on the spring/strut?
Thanks for the feedback.
      01-05-2019, 02:24 AM   #29
brad850csi
Everything in the suspension is the same as the F10 M5 apart from spring rates so there shouldn't be any problems with physical fitment. You'd need a 15mm spacer just to get to stock specs. Also the M5 wheels are 10" and M6 wheels are 10.5" which very slightly stretches the tyre so even with a 15mm spacer you're still slightly inset from stock.
The good news if your front wheels are correct (20x9.5" 31mm) that you'll only need to buy two wheels and then have a good pair of wheels that can fit anywhere on the car and can be used as a spare. If you check out one of my threads you'll see 20x10" M5 343m wheels on the front of my car with 295/30r20 tyres and they are absolutely fine over speed bumps and full lock.
      01-09-2019, 03:53 AM   #30
dclin
Drives: FD3S
Leo.
How did you measure the wheel width? Nominal wheel width is measured inside the lips. If you are measuring 10.5" from outside lip to outside lip, then it's probably more like a 9.5" width wheel.
      02-07-2019, 06:56 PM   #31
KrutoyM6
Drives: 2019 F90 M5 Comp
Originally Posted by frozenM6 View Post
2015 competition
So this is 12 rear and 10 front?
      02-07-2019, 09:27 PM   #32
frozenM6
Drives: BMW M6 CP
2015 competition
Yes
      02-07-2019, 10:29 PM   #33
BM dnobagaV
BM dnobagaV's Avatar
Drives: 2010 BMW 528i
2015 competition
Wow, is that a custom wrap? Looks
In regards to getting spacers, did you also change the studs or keep OEM ?
      02-08-2019, 11:03 AM   #34
frozenM6
Drives: BMW M6 CP
Stocks worked. No change.
      02-08-2019, 12:10 PM   #35
Havy
Havy's Avatar
Germany
303
Drives: BMW X5 M50i
I forgot to keep you guys updated. I installed 10/10. I was going to install 12 on the back but the 295 tires are actually 325 and than 12 would be too much.
