      02-07-2019, 11:46 AM   #1
KrutoyM6
Best Tire and Wheel Spacer
So I have an m6 Gran coupe. Iím not interested in lowering at the moment, not until I move in the next year or so. Believe it or not, the only driveway Iíve ever scraped on is my own, itís super steep, not ideal for car enthusiast lol.
I also donít want to buy new wheels and like the look of my factory 601m comp package wheels powder coated gloss black. Those wheels are a 20x9.5 front and 20x10.5 rear. My tires are stock size MPS4s, which is 265/35/20 front and 295/30/20 rear.
So, since Iím not lowering it and I donít wanna buy new wheels, whatís the widest tire I can run and what size wheel spacer should I get with that tire to be flush?
To break down that question a bit more:
For the fronts, do I keep stock size tires? Is there any benefit to going to 275s? Any negatives? Iím guessing 285s wonít fit can somebody confirm this.
I was told wheel spacers in the front can cause a lot of issues so should I just not bother with front wheel spacers?
In the rear I was told 305/30/20 is the best size to run and 315s arenít really available with a good aspect ratio on MPS4s for the stock wheels, is this true?
Without lowering, whatís the best size spacer to run in the rear with 295/30s? With 305/30s?
      02-08-2019, 08:04 AM   #2
mgmarsh39
mgmarsh39's Avatar
102
Drives: M6 Gran Coupe
I run 305/30/20 rears 4s with no spacer on stock 433s.
E92 M3 - AW, 6Speed, Speed Cloth, No Nav, Carbon Roof
      02-08-2019, 02:38 PM   #3
MelbourneFinn
Drives: 2017 M6 GC
Donít touch the front tyres, they are good as they are. For a bit improved grip in the front, go for 305s, but forget about the spacers unless you are going to modify for significantly more aggressive look. And get your wheel alignment checked and adjusted by someone who knows what they are doing, a lot more important than changing rubber...
      03-06-2019, 12:22 AM   #4
hirkaismyname
Drives: F06 2017 Grigio Telesto Perl
305's in the front MelbourneFinn ?! I thought 285 was the max you could go in the front and 305 max in the rear.
      03-06-2019, 01:51 AM   #5
MelbourneFinn
Drives: 2017 M6 GC
Obviously a mixup with words - 305s rear, 265s front
      03-06-2019, 07:16 AM   #6
mikerx5
mikerx5's Avatar
34
Drives: 2014 F06
2013 BMW X6  [0.00]
So forget spacers in the front? Is that the suggestion? And spacers in the rear are ok - if so what size?
      03-07-2019, 04:33 AM   #7
ts-m6
Japan
15
Drives: 2014 F06 M6 GC
if your wheels are:
front 20x9.5 +31
rear 20x10.5 +19
and, your tyres:
265/35-20
295/30-20
you won't have issues running 10mm spacers all around, especially if you're not lowered.
fyi, I'm lowered on KW HAS kit with wheels and tyres size indicated above and running 12mm spacers all around and I find no issues. by the way, my tyres are PZERO.
if you're planning on 305/30-20 tyres with 20x10.5 +19 wheels for rear, you should still be fine with 10mm spacers, especially if you're not lowered. (but with 305/30-20 PS4S, it may become a different story, so you'll just have to experiment to find what works for you)
try experimenting with:
10 to 12 mm spacers for both front and rear
you might want to check willtheyfit.com
