03-16-2021, 12:08 PM | #1 |
Rep 7
Boot is closed, no battery! HELP
Hello all
I have a 640D Coupe 2013 and I took the battery out of the boot to charge it. Unfortunately it started raining and I closed the boot. So now the battery is charged I can't open it to re-connect it. I have tried applying some power to the front battery posts but all is dead. There is no physical keyhole. There is no way in through the back seats unless I force my way in, even then I am not sure I can open a UK model like that. I don't think there is a grab handle. Has anyone got any suggestions before I call BMW!!! |
03-16-2021, 01:27 PM | #2 | |
Rep 34
Drives: 640D M Sport Gran Coupe
Your drivers door will have a keyhole so you should be able to get into the car. If you have folding rear seats you can take out the ski hole box between the rear seats to access the boot/trunk. From there you can reach (might need something to extend your reach) the pull lever to fold one of the seats down. That will allow better access into the boot/trunk. Not sure how to help if your rear seats don't fold down. Once in, there is a boot/trunk release cable on one side, near the seat release levers. Good luck! |
03-16-2021, 02:48 PM | #4 |
Rep 1,822
Drives: BMW iX Xdrive40 MSport
Coupe was never offered with folding rear seats. Ski hatch is a solid suggestion. Not sure if you can access the trunk area when removing the rear seat backrests on the coupe, but I know that you can't on the vert. I may be wrong, but the I think that since there is no battery to close the power loop powering through the hood jump points would not work.
*IF* you can get into the trunk through the rear seats you should be able to get the trunk floor cover up to get the battery into place. It's likely not going to be easy at all, but that's the only solution I can think of. Not having a mechanical key option for the trunk is a wee oversight imho.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic Last edited by hugo_nz; 03-16-2021 at 02:55 PM.. |
03-16-2021, 03:24 PM | #5 |
Rep 7
I can get into the front of the car fine. I didn't fully close the doors. I don't have folding rear seats in the coupe. I managed to remove the centre panel from the rear seats which contain a first aid kit (didn't know that) but behind is what looks like a solid panel. I could probably force my way in but don't want to cause too much damage. Is there a trunk/boot release inside on the UK coupe? I've never noticed one.
I don't think there is anyway I could reconnect the battery from the back seats. |
03-16-2021, 06:05 PM | #8 |
Rep 1,822
This is unlikely to work since the power circuit of the car is open owing to no battery being installed. On other models this was solved by applying power directly to the appropriate junction box. This will likely cost a trip to the BMW workshop.
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
03-16-2021, 08:00 PM | #9 |
Rep 285
Seen it happen to a few others, basically it ended up having to go to the dealership to get it open. There is no 'cheat' to open it. Anything you try will be forceful and not worth it. Dealers can get access apparently.
M Sports Edition Carbon Wing Carbon Front Splitters Carbon Rear Diffuser Carbon Grilles Powder Coated 373m Triple Bronze CPG intakes Arm catless downpipes Arm charge pipes Custom Snow Performance methanol injection Custom exhaust, straight pipes to quad tips Bootmod3 Stage 2 3.5 Tmaps xHP Stage 3 |
03-17-2021, 03:20 AM | #10 |
Rep 659
if you have the ski hatch try jump leads to the connectors and get the battery in the rear seats
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5, Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff |
03-18-2021, 05:37 AM | #11 |
Rep 7,467
If you used the correct jump start terminals in the engine bay...and supplied sufficient power...this should allow you to open the trunk using the switch in the driver’s footwell or the remote fob or the trunk Roundel mechanism.
Failure to open (when doing the above) usually occurs when an incorrect grounding point is used. Make sure you’re using the dedicated ground BMW provided and indicated in the owners manual. This should work even when the battery is disconnected unless you also undid the battery safety terminal, too...thus disconnecting the main fuse box from the positive cable that connects the front engine bay terminal to the main fuse box. See engine bay images below for correct pos/neg engine bay terminals...if you used a bolt on the strut tower or other ground location...this could be the problem...it may not be truly grounded. The image below shows the positive battery cable connections...and even though the illustration shows an e53 X5...BMW uses the same basic design in newer models since they all have a BST (battery safety terminal). Even if the pos battery cable is removed from the battery...the BST keeps the positive battery cable connected to the vehicle’s fuses & relays (if the BST isn’t blown)...this is why & how supplying power to the engine bay terminals allows the car to be powered even if the battery is removed:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-18-2021 at 03:46 PM.. |
jjasonSU194.00 |
03-25-2021, 06:50 AM | #12 |
Rep 7
Hello, yes I have connected the battery to the front battery posts as described. Many thanks for the photos. There is still no power at all? I did get a spark when I connected the ground, I assume that is normal?
04-02-2021, 03:21 PM | #14 |
Rep 7
Sorted!
I spoke to my local BMW dealership who I bought the car from and they were not helpful at all. So I ended up getting the vehicle towed to a garage. They had it open in a less than an hour. Apparently via the fusebox. It cost me £100 which included the tow. Lesson learnt!!!
Frupal791.50 |
04-03-2021, 02:01 AM | #15 | |
Rep 1,822
06-09-2021, 02:13 PM | #16 | |
Rep 4
03-15-2022, 01:57 PM | #18 |
Rep 2
Drives: BMW F13, BMW E90, Mini R53
03-15-2022, 03:50 PM | #19 | |
Rep 7,467
Your car will be powered by the other battery or battery charger etc...it won't need your battery with the disconnected negative battery cable. It also doesn't take a lot of power to unlock the doors or trunk...so even a small 2-4 amp battery charger should be enough to unlock the trunk when using the jump terminals in the engine bay.
JBF650115.50 |
03-22-2022, 11:56 AM | #20 | |
Rep 19
Just for future reference, how did they get the trunk open through the fuse box? Did they remove a fuse? |
12-07-2022, 04:06 PM | #21 | |
Rep 2
Worked perfectly using jump cables...
No need for the RAC or the dealer - just some jump cables and another car. Thank you Qsilver7 |
12-07-2022, 05:32 PM | #22 |
Rep 7,467
…glad you got it sorted out and thanks for updating the thread with a verifiable solution.
Frank Duncan1.50 |
