06-14-2019, 11:31 AM | #1 |
Rep 76
Clunking in front end
Has anyone ever had a cluncking noise in the front end of their GC? I've got a 16' 640i GC and there is a clunking noise I notice at slow speeds, especially as I as I have the windows down and pull in or out of the garage. It's not under wty but the dealership said its likely the floating brake rotors?
06-14-2019, 09:08 PM | #2 |
Rep 1,698
Very hard to say as a myriad of problems can cause noises like you're describing. Is it happening only over bumps? Straight line? Only when turning?
Needless to say, you'll need someone to look at it. Some "typical" noises you might develop from the front-end suspension are usually tied to control arms going bad. If you hear noises typically over bumps and feel some play in the wheel, that could be the case. If it's happening on perfectly flat surfaces in a straight line, perhaps not. Again, it'll be tough for anyone to diagnose over a forum, so I'd probably just get it checked out.
06-17-2019, 01:49 PM | #3 |
Rep 282
yup. Could be anything. If you really want to know and taking to a garage or getting under it and poking around doesn't do it you could try getting a set of chassis ears.
06-19-2019, 01:26 PM | #4 | |
Rep 76
My initial thought was control arm bushings as on the old e46's, e60's etc this was always an issue but I felt like i'd read they'd changed that design up so that this wouldn't be an ongoing problem. |
