      06-12-2019, 07:06 AM   #1
SpokenHands
Certified Car Nut
SpokenHands's Avatar
67
Reverse wing mirror dip
The reverse wing mirror dip on my car works intermittently - about 50% of the time. Is there a software reset procedure like on the tilt sunroof?
All other electric functions on the wing mirrors are fine - folds, manually tilts and moves, just the auto dip function does so only half the time.
Been this way a year, and has improved a bit since I buzzed the assembly with WD40
Any ideas??
Current: 2018 Range Rover Velar First Edition D300 HSE + 2018 AMG GT-C Coupe + 2013 6 Series BMW GranCoupe (October)
Retired: 2016 AMG-GTS Coupe, 2013 & 2012 Maserati GranTurismo MC Stradale,2016 3-Series Touring, 2009 5 Series GT, 2007 BMW M5, 2012 & 2006 BMW 1 Series
      06-12-2019, 08:04 AM   #2
Opie55
Drives: '15 650i Convertible
Somebody had a post exactly like this one a couple months or so ago. In fact, I thought it was the same one with a new reply that brought it back up top. You might find that and PM that OP.
      06-12-2019, 10:42 AM   #3
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / E53 X5 4.4
Any ideas??
Question...are you familiar with how to disable the tilt-in-reverse feature? If not...can you definitely say that the switch is NOT in the disable position the times that it DOES NOT work?
2006 E53 X5 4.4 | 2013 F06 650ix Gran Coupe`
BMW CCA Member #191509
      06-13-2019, 02:49 AM   #4
SpokenHands
Certified Car Nut
67
The mirror setting point on the door card is in the correct position.
This is not the issue.
      06-17-2019, 11:29 AM   #5
SpokenHands
Certified Car Nut
67
May work
This may actually sort out the reverse dip mirror issue
https://f30.bimmerpost.com/forums/sh...=844155&page=2
"Slide the mirror selector switch to the passenger position.
Momentarily touch the mirror adjustment switch.
Slide the mirror selector switch back to the driver's side.
Normal tilt operation will be resumed."
Copyright ©2000 - 2019, vBulletin Solutions Inc.
