06-10-2019, 10:00 AM | #1 |
Rep 107
Charging Malfunction
so while driving i got a charging malfunction error code on the dash. about a minute later i get a message that the engine temp is too high but when i check the gauge it's floating at around 200.
any ideas what the issue could be or how to trouble shoot? i'm hoping it's just a battery issue. |
06-10-2019, 08:20 PM | #2 |
'14 M6 GC Comp Owner
22
Rep 53
I don't know if it's a battery issue ... I'd probably check the coolant. It may need a flush service but I could wrong. This is the first thing that popped in my mind.
[Owned] 2015 BMW 640i xDrive Gran Coupe
Driving 2014 BMW M6 Gran Coupe Comp Still on the hunt for '14 - '15 M6 GC Comp or '20+ X4M Comp in San Marino Blue with White Interior |
06-18-2019, 03:53 AM | #5 |
Rep 38
This is what I thought but you didn't mention anything about the power steering and I believe this car carries one belt so it should have been affected. In addition, you should check to find out why this happened. Just replacing the belt itself is a short term fix because whatever damaged the belt is going to do so again. I would assume one of the idler pulleys or the belt tensioner has failed.
sixfiftyay45.50 |
06-18-2019, 05:55 PM | #6 | |
Rep 107
