04-24-2019, 01:16 PM | #1 |
Rep 24
Wireless Charging Retrofit
I've seen the posts before where people talked about retrofitting wireless charging onto the 6 series using the BMW OEM part no. 84102449887.
Basically this replaces the existing phone mount with a snap in dock that will wirelessly charge the phone. However, it still has the problem of occupying a large amount of space in the console. I note there appears to be a second type of OEM wireless charger release by BMW which is seen in the link below. This one is more like a pocket that the phone slides into and seems far more space efficient. https://www.autoevolution.com/news/b...28.html#agal_2 There are three questions ultimately for this: 1. Can this part be retrofitted onto a 2013 F06 (or any pre face-lift 6 series)? 2. If so, what part number is this? 3. Has anyone done this before? I searched on here and found no examples. |
04-24-2019, 02:44 PM | #2 |
Rep 7,477
Click the link below and scroll down to the wireless charging case info...click and you'll be presented with a vehicle information drop-down box to see if it fits your BMW. The part 11 digit BMW part nbr listed on shopbmwusa.com is 84212449610:
EDIT: did a bit more searching...it seems to be in the early stages of being released. The "wireless charging case" appears in the diagram for the G chassis 7 series as item #2...but item #2 is NOT listed in the part nbr index below the diagram.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-24-2019 at 03:07 PM.. |
04-24-2019, 08:05 PM | #3 |
Rep 11,891
Considering it's a $500 battery and easily $1000 of other power equipment, I wouldn't use the car to charge a phone.
I never charge my phone in the car. It's cheaper to use a separate power bank
04-24-2019, 10:08 PM | #4 |
Rep 2,349
At the moment my built in USB port always has a lightning cable connected to it to connect to my iPhone and I use the cigarette lighter in the centre console to charge power banks that I use if I'm going away for a week, going on a hike, or need to charge my Cygnett 27,000mah USB C power bank that can charge my X1 Carbon via USB C)
I don't see an issue with using either port while the car is running but I'm definitely worried about using it if the car isn't running and draining the battery.
