      06-12-2018, 07:07 PM   #1
av.7447
Drives: E39, E60 M5, F06 M6, F15, F90
M6 Vs M6 ZCP
Hey,
I just drove the M6 GC Competition back to back right after my non competition M6 GC .... Call me crazy but I did not feel any difference at all... I tried it in all kinds of settings and took my time testing it in turns and acceleration and if anything my transmission felt tighter but that’s probably because it’s just newer... The steering feel is exactly the same and is as direct as a non competition... the suspension felt exactly the same... the only noticeable difference was a slightly cooler sound which came from the akrapovic exhaust... both cars parked together the suspension is exactly the same height...Am I missing something here? Where did that $6500 go ???
      06-12-2018, 07:42 PM   #2
BM dnobagaV
BM dnobagaV's Avatar
Drives: 2010 BMW 528i
No ride height difference? Yours isn't lowered any extra to match it? If that's the case, & the steering isn't superior, then I can probably comfortably scratch having the Comp Pack off of my desired(but not necessary) list.
Wouldn't see the point in throwing down the extra $$
      06-13-2018, 11:40 AM   #3
av.7447
That’s what I said... ride height is exactly the same... Maybe if you are a Lewis Hamilton and you take both of these cars on a track and drive them back to back for the whole day then maybe, just maybe, you will be able to figure out a difference between them... but my butt dyno tells me they are both exactly the same apart from the exhaust note... definitely not worth the extra money they are asking for that competition package.
      06-13-2018, 11:58 AM   #4
rsuhandy
rsuhandy's Avatar
Drives: F06 M6;E92 M3;E85 Z4M; 958 SEH
It's 15-35hp at the very top of the rev range (Depending on MY).
Most people will not be able to feel that.
I believe ride height is also the same (ZCP lowered the M5 not the M6).
What you should feel is the quicker steering and stiffer suspension.
I've driven both ZCP and non-ZCP back to back and the steering and suspension are very noticable. If you can't feel the difference then you shouldn't get it, but that's why I tell everyone to drive both and see if they can tell.
Flying Ace4984.50
      06-13-2018, 02:21 PM   #5
spikespiegel
Drives: BMW M6 comp
Theres also a difference in the M Diff between the CP and nons, right?
      06-13-2018, 05:41 PM   #6
av.7447
So they say... I call bullshit... the diff on a standard car is already very aggressive... nothing much else they can do there... different software? 🤔
For example, not a lot of people know that the first gear on the M6 is shorter than on the M5... Nooone is sure exactly what else they did to the standard M6 but it feels way sportier and faster than the M5.
      06-13-2018, 06:02 PM   #7
rsuhandy
rsuhandy's Avatar
http://f10.m5post.com/forums/showthread.php?t=842219
Just reference this post...
Also I stand by my original opinion.
Just drive both to determine if you think it's worth it.
The market suggests that ZCP cars command a premium, so apparently enough of the market thinks it makes a difference upon on resale.
I for one noticed a significant difference, another driver might not notice it, and therefore can pay less to get a non ZCP car.
      06-13-2018, 06:19 PM   #8
av.7447
This post you are referring to talks mostly about the M5... I highly doubt the M6 has the same treatment as a lot of people even in reviews were claiming that the standard M6 feels like the M5 with CP... There is not a one single video on Youtube that is actually comparing those cars (M6/M6CP) in detail. More direct steering you say? Drive the 2008 E60 550 with active steering and tell me which steering is more direct, the E60 or the M6CP... there you will feel a huge difference in steering... M6 and M6CP feels the same unless my 2018 model year already has CP steering as standard... 🤔
      06-13-2018, 06:33 PM   #9
Siciliano611
Drives: SMB M6GC
You're just trying to justify your opinion....I test drove both and there's a big difference, steering and tightness overall feel of the car is improved on the ZCP as is the top of the gear speed by a slight feel....Get what you want but they didn't just hoodwink everyone with a upgrade that was nothing
      06-13-2018, 07:08 PM   #10
rsuhandy
rsuhandy's Avatar
I thought we were comparing ZCP vs Non-ZCP...
I also happen to have an E60 550i with DHP so ya...
Like I said before, no one is suggesting that what you "feel" is wrong.
But most of the community feel different about it...
      06-13-2018, 11:25 PM   #11
Flying Ace
Flying Ace's Avatar
4985
I suspect OP actually drove two of the same cars. Do you have the VIN of both cars?
rsuhandy110.50
      06-14-2018, 10:00 AM   #12
rsuhandy
rsuhandy's Avatar
This would explain a lot.
Maybe the CP car isn't actually a CP car, or maybe your car is...
Most people I've talked to notice a significant difference between the way a ZCP car vs a Non-zcp car drives.
      06-15-2018, 01:38 AM   #13
evanescent03
evanescent03's Avatar
1032
Drives: '24 M3 CS; '22 GT4
agree with those above. if you don't notice the difference with your driving habits... probably not worth it. however, worth double checking to make sure the one being labeled a CP actually does have that pkg. obviously you can't got totally wrong here! good luck!
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
      06-20-2018, 04:17 PM   #14
M6 in Bama
M6 in Bama's Avatar
Drives: 2014 M6 Vert, Saphire Black
What year and how many miles on the CP version you drove vs your 2018?
      06-20-2018, 06:28 PM   #15
Flying Ace
Flying Ace's Avatar
4985
OP wasn't able to confirm that the car he drove was actually a CP. Given that everyone else says they can tell the difference and that OP hasn't provided the VIN of the car he drove, we're assuming he drove a non-CP car with a MPE.
Maybe as OP was in Canada, it was really cold and he was wearing some thick Goretex body condom:
      06-21-2018, 01:28 AM   #16
av.7447
lol, FlyingAce, do you have anything else to do other than spy on this forum 24/7? Does anyone even work here??? 😅 I am still working on those photos I promised you... maybe coming in August now as I am back at work and didn’t get much time to enjoy my new car!
I did drive it in Canada, haha, and it was in fact competition M6. I wasn’t born yesterday... I didn’t get the VIN of the car when I was at the dealer on the M tour, so I can’t provide it to you. No point of arguing any more as I already stated my opinion and I will repeat that again: My e60 550 steering is more direct than that of a cp M6. Also I didn’t feel any considerable difference in the M6 CP and my non CP M6. The extra 15hp on topend, that’s a “maybe” as I unfortunately didn’t have a chance to hit 160mph on that day...if anyone here cares, I also happen to drive an M5 while i was there and it felt like a Cadillac on steroids compared to the M6. The new M5’s suspension on the Sport Plus setting felt softer than a comfort setting on my non CP M6. Overall I enjoyed a manual M2 the most and I am glad I got a 2018 M6 over the new M5!
The moral of the story is, do not wait for the M6 CP if you are buying one, I would rather have a B&O over CP... it is not a day and night difference. If you are getting a new one and dont give a f about money, might as well click that CP check for your personal inner soul satisfaction... other than that, if you need more power, get a tune...
Flying Ace4984.50
      06-21-2018, 02:56 PM   #17
Flying Ace
Flying Ace's Avatar
4985
I'm curious now, can you provide us at least a description of the car and the dealership name? It might still be posted for sale.
Often webpages are archived and I can still find the old posting of the car. Many of us really feel you didn't drive a ZCP car.
VIN is overkill, but even a photo of the tailpipes, window sticker, the aforementioned description will go a long way.
      06-21-2018, 05:40 PM   #18
malcoll
Drives: 2014 M6GC BSM/SO
i have to agree with av.... I drove both multiple times and I found no difference, to the point that I bought a non-CP M6. I'm pretty familiar with performance vehicles and I could not tell a difference in performance between CP and non-CP. But that's just my opinion, I know what I drove and what I felt (and didn't feel....which was any difference). So I feel good about my decision not to buy CP. Flame-suit on!
      06-21-2018, 07:50 PM   #19
av.7447
Dude, let it go 🤣. It is an M tour from BMW Canada. They have all the M cars which they take dealer to dealer around Canada for people to go and test drive them. These cars are not attached to any dealer. You want the picture of the exhaust pipes? 😅😅😅 .... it had an Akrapovic exhaust that comes with ultimate package in Canada as standard. The ultimate package also includes all the possible options except carbon ceramics as standard.
      06-21-2018, 08:15 PM   #20
Flying Ace
Flying Ace's Avatar
4985
Got it, I read it that it was at the dealership. Didn't know you were driving a tour demo car.
      06-21-2018, 08:45 PM   #21
rsuhandy
rsuhandy's Avatar
I don't agree with your moral of the story...
Maybe some of us are just more sensitive to the CP changes.
Either way all you are stating is opinion and the rest of the community is entitled to theirs. You are saying the CP isn't worth it, which is fine for you since you can't tell the difference. But saying that there is no difference is essentially saying that the rest of us are morons; did you really not expect any push-back...
1MEANM628.50
