      09-22-2019, 08:27 AM   #1
MichaelInChicago
Drives: 2015 BMW 650xi GC
Ambient lighting
Is there any way to increase the brightness of the ambient lighting in a 2015 650 GC? Unless you place your fingers directly under the any of the door's interior ambient lighting, you cannot even they are there.
Thanks
      09-22-2019, 10:28 AM   #2
MingLu
Taiwan
Drives: 650i xDrive GC
I did increase the light by BimmerCode app.
MingLu
      09-22-2019, 01:08 PM   #3
Qsilver7
Qsilver7's Avatar
Thanks
What color is your interior?? With the 1st iteration of the interior ambient lighting option, the lighting isn't that bright and a dark (black) interior makes it seem almost invisible until you're in an extremely dark location. If you stick a white sheet of paper below the light locations...you can see the light is actually shining.
      09-22-2019, 01:44 PM   #4
Bigjule1111
U can get it coded to full brightrness.. my interior is ivory
      09-22-2019, 03:30 PM   #5
Giggs11
Giggs11's Avatar
52
Drives: 13' f13 650i xdrive,M package
Under what Column is interior brothers on bimmer code ?
      09-23-2019, 08:49 AM   #6
Qsilver7
Qsilver7's Avatar
Originally Posted by Giggs11 View Post
Under what Column is interior brothers (???) on bimmer code ?
If you're asking where to find interior ambient light adjustment...I believe it is under the FRM (footwell) module or FEM (front electronics) module...I forget which one it's called for a 2013.
But don't get your hopes up too high because the early version is not going to be nearly as bright as the latter models that can change colors to look like a night club/brothel/etc.
Your interior ambient lighting is similar to the original (muted & yellowish hued) Angel Eye/Halos vs the later (piercing bright white) LED corona rings. The 1st iteration was designed to be subtle & muted.
      09-23-2019, 01:38 PM   #7
MARKPRIOR
157
Drives: 2017 M6 GC
Hmm need to investigate turning thos up o NBC mine, PITA that it changes with the clock illumination also
      09-23-2019, 04:18 PM   #8
jjasonSU
Drives: 650i, NSX
Originally Posted by Qsilver7 View Post
Is the latter models that can change colors to look like a night club/brothel/etc.
really
      09-23-2019, 04:40 PM   #9
Qsilver7
Qsilver7's Avatar
If memory serves me correct, I think there's an option in BimmerCode to separate the ambient lighting from the instrument cluster lighting (can't recall the exact wording at this time)...but it looks like it was there so that you could code the ambient lighting at 100%...but then be able to dial down the instrument cluster lighting so that it wasn't at its max setting just to blaze the ambient lights.
Originally Posted by jjasonSU View Post
really
...just a friendly dig at the newer light package...only because I wouldn't call it "ambient" lighting if it is no longer "subtle".
      09-23-2019, 06:38 PM   #10
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
In the '14 M6GC with black interior an B&O audio, the ambient lighting is difficult to see unless it is absolutely dark outside. I have it set at max brightness.
had it checked out but that is all she will do...
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
