11-23-2020, 03:28 AM | #23 | |
Rep 149
12-13-8-647-689 Or 12-13-8-611-236 Im confused ?? Last edited by aann; 11-23-2020 at 05:52 AM.. |
11-23-2020, 09:41 AM | #24 |
Fueled by Recycled Dinosaurs!
632
Rep 1,172
Drives: F06 M6
Do you know your production date?
11-23-2020, 06:00 PM | #26 |
632
Rep 1,172
Drives: F06 M6
I was looking on realoem.com and thought I'd find a conclusive part number based on build but it looks like either are valid. The coils are Genuine BMW part numbers the ones ending in 236 state for years 2016-2018, made by delphi, and the part ending in 689 are for 2002-2018, made by bosch.
Seems like either are valid but you could buy the Delphi or Bosch branded equivalents far cheaper and they are the OE providers.
11-24-2020, 06:41 PM | #28 |
632
Rep 1,172
Drives: F06 M6
Visually different but functionally the same but one would think they'd have some guidance on them.
11-29-2020, 08:07 AM | #31 |
Rep 149
12-11-2020, 06:58 AM | #32 |
Rep 149
12-13-2020, 12:43 AM | #34 |
Rep 582
12-13-2020, 07:50 AM | #35 |
Rep 747
12-14-2020, 12:16 AM | #36 |
Rep 359
Id say every 20-30k stock and every 10k tuned. Yes don't play with injectors, i would replace them before they even show signs of failure if i were you. I have 40k kms on mine and changing them right away. If they leak, you will have misfire codes and they will dilute the oil and can cause a lot of issue (detonation/bend rods, rod bearings failures)
12-14-2020, 03:35 AM | #37 |
Rep 149
Here is what i see on ista , misfire on cylinder 4 , but the p0299 fault code ( charge pressure low ) that i had at first is not exist .
The car still reduce power on accelaration . Last edited by aann; 12-14-2020 at 03:45 AM.. |
01-24-2021, 03:23 AM | #39 |
Rep 149
Okay , finaly we found the the problem : 🙄
01-24-2021, 12:04 PM | #40 |
632
Rep 1,172
Drives: F06 M6
is that cotton packing material in there?
01-25-2021, 09:09 AM | #41 |
Rep 149
01-28-2021, 12:10 AM | #42 |
632
Rep 1,172
Drives: F06 M6
Jeez. I don't know if I would be livid or thankful. Glad to hear it was something simple though.
02-07-2021, 05:39 AM | #43 |
Rep 149
TinCanSailor631.50 |
