04-28-2021, 07:40 PM | #1 |
Rep 147
Rear tires on 21s
I know most people run 305/25 21s which is what I have currently. I was wondering if anyone is running 325/30s ? I realize there's about an inch difference in diameter so wondering if it's even possible. Possibly even changing fronts to a 265/35?
Reason I'm asking is there's more choices in that size and a 30 sidewall would be nice for the roads here. |
04-29-2021, 11:22 PM | #2 |
Rep 2,349
A lot of people have been running 325/25r21 which still has a slightly taller sidewall than your current 305. I doubt a 30 will work at all unless you cut down to 285/30r21 or maybe 295/30r21 but your front will need to be a 265/35r21 with those options.
How wide are your wheels and what offset? Based on that pic they look like 11" or 11.5" and around 20mm I think?
04-30-2021, 09:45 AM | #3 | |
Rep 147
I still have my stock 20s I may just use if I visit the track and put a good rear tire on it |
04-30-2021, 07:19 PM | #4 |
Rep 2,349
With those spacers you'll be able to run 325/25 just fine, that is the same effective offset that I'm running
https://www.6post.com/forums/showthr...hlight=ferrada I still think if you want to run a 30 profile you'll need to go down a bit in width
05-05-2021, 09:40 PM | #5 | |
Rep 417
FYSA, a 325/30/21 is far too tall for the M6 and it can cause significant damage to the ECU, Transmission, and Suspension.
Full Vorsteiner Aero Kit, ADV5.0 M.V2 CS rims, KW HAS kit, M Performance Exhaust w/ CF tips, CF Mirror Caps, CF Gear Selector Lever, CF Side Marker Gills, CF Front Grill, Dinan CF Intake, AFE CF Engine Cover, Stage II Dinan Tune, Exhaustmeister, Internal Escort 9500ci + Laser Shifters, Photosync window tint 65% windshield 35% windows, Full PPF xpel ultimate wrap, RK Autowerks noncatted DPs, reflector delete, various coding
05-10-2021, 10:31 PM | #6 |
Rep 81
I ran 265/35/21 on the fronts and it seemed ok. I don't remember getting any rubbing but it the tire was pretty darn close to the suspension. I ran 305/30 on the rears, so sorry I don't have any input on that.
2016 M6 Gran Coupe
2006 325i |
