      01-08-2019, 02:25 PM   #1
Xx__xs
Drives: m6
fixed
      01-08-2019, 02:57 PM   #2
Jasoneo5
Drives: 997 TTs, GS-F, RS6, M6 GC-sold
I have this too, but in the rear door. Subscribed for tips
      01-08-2019, 02:57 PM   #3
BMWDriverX
Drives: G12 750i X-Drive
Originally Posted by Xx__xs View Post
I noticed a rattle from my bang and olufson front left side door speaker. The one thats under the window, bigger one. when i set the bass to anything more than the medium setting it rattles like theres something stuck in it. how do i go about fixing this? very annoying
The speaker is either blown, loose, or the outer grill is loose. I would take it to a stereo shop, I'm sure a decent one could fix it quickly. I would not want to mess with tearing down the door panel.
      01-08-2019, 03:00 PM   #4
Xx__xs
Drives: m6
i hope its not blown. i doubt it can be, it sounds fine, just at high bass it sounds like there are some crumbs or some object in the door storage compartment being shaked by the bass.
i hope this shits covered by aftermarket warranty that i have
      01-08-2019, 06:17 PM   #5
Cincinnatus
Drives: 2013 M6
I might be mistaken, but I don't think a warranty will cover the effects of eating potato chips in yiur car.
      01-08-2019, 07:00 PM   #6
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
The door panel is relatively easy to pop out from the bottom. It's just held in with snaps... You should be able to access the speaker from underneath without taking the whole thing off the door.
      01-09-2019, 06:23 AM   #7
Xx__xs
Drives: m6
i just got the car 3 weeks ago with 40k miles on it and extended warranty. never ate in it
      01-09-2019, 06:24 AM   #8
Xx__xs
Drives: m6
pop it off to check it out or what?
      01-09-2019, 12:36 PM   #9
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
Yeah, maybe check to see if anything is loose, or falls out when you pull the panel out.
Xx__xs201.00
      01-09-2019, 01:27 PM   #10
kong24680
Extended warranty should definitely cover this.. I would take your car straight to the dealer and have them work on it.
      01-09-2019, 02:48 PM   #11
Xx__xs
Drives: m6
its extended aftermarket warranty though. not factory
      01-09-2019, 02:52 PM   #12
kong24680
You can totally use your extended warranty at bmw. Your extended warranty will most likely cut a check to bmw after repairs are finished. You may have to pay a deductible depending on your warranty.
      01-09-2019, 03:40 PM   #13
Cincinnatus
Drives: 2013 M6
That sucks for sure. Hope it's nothing big bad.
      01-10-2019, 07:43 AM   #14
mgmarsh39
mgmarsh39's Avatar
255
Drives: E92 M3
FYI, this was my rear panel, but may help you if you decide to pop your front.
https://www.6post.com/forums/showthread.php?t=1485989
      01-10-2019, 11:34 PM   #15
Xx__xs
Drives: m6
thanks.
i made an appointment with the dealer guys. they got me a loaner too. we will see on tuesday
      01-15-2019, 12:59 AM   #16
Xx__xs
Drives: m6
update: PENN warranty does not cover speakers so I cancelled my appointment.
Miraculously the bass rattle went away today morning. no idea why.
