      10-04-2020, 10:10 AM   #67
Bigjule1111
honestly I'm not sure whats the maker of my unit or if I have the latest software.. this is a pic of the info on my unit .[IMG]undefined[/IMG]
      10-04-2020, 05:51 PM   #68
Thewrench86
From the software cust version you have Carlinkit
      10-04-2020, 07:15 PM   #69
Bigjule1111
So do u think my software is up to date ? Also just noticed my heads up display not functioning... Anyone have a issue with this during install ? Nothing shows up on my windshield and grayed out on my idrive screen ..I did have it gray out when I was coding last year ..maybe tomorrow I'll hook up on bimmercode and see if I can get it back on .. Thanks again
      10-05-2020, 02:04 AM   #70
Thewrench86
There are no newer versions available via the thread
https://f30.bimmerpost.com/forums/sh....php?t=1675929
Regarding hud maybe a wire was not reconnected during the install process?
      10-05-2020, 03:17 AM   #71
Bigjule1111
Not sure .I'm going to mess with it in the morning..but I did have the same issue when I was coding ..it just disappeared.and I wasn't coding anything to do with the HUD. It just grayed out and It deactivated itself , so I'm hoping it's something simple ..if not then I'll take car back to the installer.. another question.. when making calls ... The correct way to connect is thru both bluetooths? I seen that for me to make calls correctly looks like the unit has to b connected to the unit and the car .. dual connection.. if not I have to manually connect the unit to the car .. the last time it connected to both and I was about to make a call without jumping out of the unit ...and thanks again everyone for helping me out
      10-05-2020, 03:20 AM   #72
Bigjule1111
here's a pic from my Android phone with dual connection
      10-05-2020, 03:20 AM   #73
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Perhaps the MOST connector is not properly connected...
      10-05-2020, 03:21 AM   #74
Bigjule1111
What's Iis the MOST connector?
      10-05-2020, 03:56 AM   #75
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Its the green fiber optic connector that's in the quad lock (big black connector) that goes into the back of the iDrive headunit.
      10-05-2020, 10:00 PM   #76
standslanted
Drives: BMW 640i, X5, 320i
Where are you all installing the MMI box on your 6? I'm installing the kit now, but have run into an issue. The LVDS IN cable that connects to the MMI box (the factory cable that in the car) is too short to install the unit in the glove box. There is space however, between the glove box and the radio but not easy to secure. I may 3D print a bracket that mounts to the metal frame in that area. There is no space behind or under the factory radio/head unit, so you will need to find another place. I can post images if interested.
      10-05-2020, 10:52 PM   #77
Bigjule1111
I got my installed by a local shop .he did have a concern about the placement.. not sure were he ended up placing it .. I do know the usb cable is running out of my glove box ..so I'm assuming is in the same spot u mentioned
      10-05-2020, 10:53 PM   #78
Bigjule1111
By the way I had a issue were I lost my HUD .. I reset the ecu to the system and HUD came back
      10-06-2020, 06:08 AM   #79
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
I did the install myself and it will fit behind the radio down below, just a tigt fit. Also, a green mist connector must be relocated, easy to miss that. Also, program your radio button 8 to aux so you will be able to get sound if you switch audio between bmw annd the mmi.
      10-08-2020, 02:59 AM   #80
Thewrench86
Are u guys able to control any movement using the scroll wheel on the steering wheel? I've seen some videos where in certain apps like Spotify the scroll wheel will work to move through a playlist say. For me the scroll only works in the phone app.
      10-08-2020, 04:56 AM   #81
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Scroll wheel works across the entire interface for me. You have to nudge it between the left, center and right columns using the iDrive controller.
      10-08-2020, 01:41 PM   #82
Thewrench86
No way, Just to be clear is that the scroll wheel on the steering wheel control to the right of the wheel??
      10-11-2020, 02:19 AM   #83
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
Yep, that's the one. Same one you would use to scroll phone numbers etc..
      10-11-2020, 01:24 PM   #84
Thewrench86
is there a setting i need to change perhaps....
      10-11-2020, 02:48 PM   #85
Mnfamilyguy2020
Drives: 2020 X4MC 2018 RR
Hmmm.... mine does not work either, The HUD gives a message that it does not function when audio input is on AUX
      10-12-2020, 04:06 AM   #86
hugo_nz
hugo_nz's Avatar
3187
2022 BMW IX  [0.00]
There is a setting. I will take a photo tomorrow.
      10-14-2020, 07:18 PM   #87
Bigjule1111
Well today I took her to work as she's not my daily driver and if I would give the mmi kit a grade , it would b a F. couldn't connect at all to my Android auto .. then when I finnaly got fed up and changed to my oem bluetooth..my phone wouldn't connect for audio .I keep connecting to dual BTs is that correct ? Then when I reversed in to my parking spot I got rear camera malfunction.. coincidence ? I don't think so
      10-14-2020, 08:23 PM   #88
Mnfamilyguy2020
That's a massive bummer, you could have a problem from installation.... Here's the mess of spaghetti I was cramming back with the added module behind the already tight head unit.
