      09-28-2017, 04:25 PM   #1
Evil Derboy
Evil Derboy's Avatar
Drives: E92 M3
Upgraded to LCI iDrive Screen
After upgrading to the newer iDrive controller, I found a good deal on a used LCI screen which is much cleaner looking and modern than the older unit.
Last edited by Evil Derboy; 12-01-2020 at 02:59 PM.. Reason: Corrected part numbers.
      09-28-2017, 11:01 PM   #2
mastatikle
Drives: m3
Could you add a before and after picture of the display please
      09-29-2017, 02:05 AM   #3
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Was new controller plug n play or did it require coding? Did you pop out or remove center console
      09-29-2017, 02:21 AM   #4
Evil Derboy
Drives: E92 M3
There's loads of pics on Google. Just type in "LCI iDrive screen 6 series" into google images.
Old screen:
New screen:
      09-29-2017, 02:26 AM   #5
Evil Derboy
Drives: E92 M3
Plug and play however I didn't bother with the touch module which would require coding. I just wanted the bigger knob...
And yes you need to take out the centre console. There's a guide on here in another thread if you search for it.
      09-30-2017, 01:08 AM   #6
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Thanks derby....
P.S. I am on holiday in Scotland...
      09-30-2017, 03:09 AM   #7
Evil Derboy
Drives: E92 M3
Thanks derby....
Are you? I hope you have a great time. PM me if you want any recommendations for places to visit.
      09-30-2017, 11:41 AM   #8
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Thanks, going home tomorrow. Visited Hadrian's Wall at Housestead today and doing a Glasgow Ghost Tour tonight.
      09-30-2017, 01:12 PM   #9
Farhan
Farhan's Avatar
Drives: F12 M6 + F15
Looks great. I've been thinking of upgrading it as well. Do you mind sharing info on where you got the parts from & how much did it cost you ?
      09-30-2017, 06:03 PM   #10
Evil Derboy
Drives: E92 M3
I got the screen used on eBay for £200 and the rear housing from my local dealer for £40.
      09-30-2017, 10:14 PM   #11
Farhan
Farhan's Avatar
Thanks for the info.
      10-01-2017, 02:28 AM   #12
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
To be clear, you still get the old display on the new screen. Your pics seem to show the nbt running idrive 5 or 6, ccc runs idrive 4. Also, the new screen simply plugged in with same plugs?
      10-01-2017, 05:05 AM   #13
Evil Derboy
Drives: E92 M3
My car already came with NBT. This photos are just two different cars that I found on google to illustrate the difference in hardware.
This isn’t an iDrive upgrade. Just a new monitor so yes whatever was on screen before will be the same but the quality of the new display is far superior. Yes new screen was plug and play. Straight swap over with no modifications required.
      10-01-2017, 10:16 PM   #14
Msizzle
Drives: 2013 M6 Coupe
great mod!!
      10-23-2017, 10:39 PM   #15
kennis827
Costa Rica
Drives: Bmw
After upgrading to the newer iDrive controller, I found a good deal on a used LCI screen which is much cleaner looking and modern than the older unit. It's also a more vibrant display (a bit like looking at the difference from the IPS screen on an iPhone versus the OLED screen on a Samsung phone).
If anyone else is interested in doing this, you need the screen and the the matching rear housing.
The job is plug and play and took me half an hour.
1. Remove black trim above steering column.
2. Remove centre trim complete with vents (this along with the trim above pop off fairly easily) and unplug the three connectors. Set this aside.
3. Unscrew two torx bolts below the iDrive screen and then gently pop it out of the housing before unplugging the electrical connector going into the back of it.
4. Unscrew the two torx bolts that attach the rear housing to the dash.
5. Complete in reverse.
It's an easy job.
iDrive screen part number: 9332142 (note that if your car comes with the TV tuner option you may require a different screen part number)
Rear housing: 936647 (again may be different re. above to accommodate screen with tuner).
hi man!
the parts number 9332142 and 936647 cant be found at ebay or google
      10-24-2017, 03:45 AM   #16
Evil Derboy
Drives: E92 M3
Originally Posted by kennis827 View Post
hi man!
My apologies. In my haste I messed up the numbers. I've corrected them in the first post.
Screen is 9332412 and Rear cover is 9364647.
Google either number with "BMW" before or after and you'll find what you seek.
      11-10-2017, 04:10 PM   #17
CJW2OO4
CJW2OO4's Avatar
Drives: E86M,M2,F13 E86&E85M,E86,2E46
Hey I am completely new to this platform. Can someone explain to me the benefits of the newer i-drive systems? (I'm coming from e86s) I am picking my 650 (2012) up tonight and want to know if I should start searching the web for the newer screen?
      11-11-2017, 07:42 AM   #18
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
CJ, the 2012 has the older cic system, NBT has a higher res screen, some more features (idrive 5 versus i drive 4), bigger controller, letter input, nicer colors. I was quoted $3,300 for the upgrade (plus install) but the loss of sat radio was a deal breaker for me
      11-11-2017, 08:59 AM   #19
Haywood
I know a thing or 2 about a thing or 2...
Haywood's Avatar
3101
Drives: E36 M3 Coupe, e39 M5, i3s
2003 BMW e39 M5  [0.00]
1997 BMW e36 M3  [0.00]
I don't understand why you can't have the SAT radio anymore after the upgrade. Can someone explain that to me?
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1
1997 Alpine White e36 M3 (the old gal)
2013 Mineral White e92 M3 (sold )
2014 Carbon Black 650i M-sport (sold)
      11-12-2017, 05:02 PM   #20
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
My guess is that the interface module is different
      11-13-2017, 04:11 AM   #21
IM6
Drives: BMW M6 F13
so no more DAB?
      11-13-2017, 05:23 AM   #22
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
"so no more DAB?" Not sure, we were talking about Sirius/XM Sat Radio, not the UK DAB sat radio.
