      06-18-2021, 05:46 PM   #1
kallan
Drives: 2013 328i Xdrive
DSC, park, Brake lights and ABS all on
Hey guys,
Went to drive my 2015 650 gran coupe after sitting out in the drive way for a couple of days. And noticed all these lights were on? Any ideas? I also have pedestrian warning limited and collision warming limited as well. Probably because of the brake lights.
I replaced my brake pads thinking maybe it had something to do with that. It still no luck.
Could it be an electrical problem?
Any help would be appreciated. Thanks.
      06-18-2021, 06:50 PM   #2
DaveS86
Drives: BMW 640I
How's the battery? Low charge makes our cars go mental
      06-18-2021, 07:19 PM   #3
Derekz4
Drives: BMW 640i. BMW Z4,01 Bullitt
The old trifecta! As mentioned above, check the battery.
      06-20-2021, 06:31 AM   #4
kallan
Thanks for the reply guys. The battery was replaced in January. So I doubt it’s that?
      06-20-2021, 07:41 AM   #5
DaveS86
Drives: BMW 640I
I'd give it a good charge anyway as a start. Have you got a way to check fault codes? Does it run and drive as normal now or have you not touched it since you got the Christmas tree lights come up?
      06-20-2021, 11:41 AM   #6
kallan
I’ve updated the op to include the codes. Car drives fine. Although I did slip and slide at the car wash because the traction control is disabled.
      06-21-2021, 01:41 AM   #7
rasa bmw
abs sensor will throw all them lights.rear nearside on uk cars ,usually the speedo and fuel gauge will go a bit mental if it.s that sensor
      06-21-2021, 10:02 AM   #8
kallan
Looks like there is something going on electrically. Might be the fuse box in the trunk. It looked like something spilled on it. Could this throw the trifecta lights?
      06-22-2021, 01:15 PM   #9
kallan
Bump
