09-16-2021, 07:11 AM | #23 | |
Rep 694
However, I feel like basements tend to have better acoustics and naturally better temps due to being underground. IMO |
09-16-2021, 07:44 AM | #24 | |
Rep 3,241
09-16-2021, 09:05 AM | #25 | ||||
Rep 1,912
Yeah at the FL house we just have an 82" TV in our living room/family room with some big floor speakers and sub. I actually like the setup a lot even though I have no rear speakers as there's no back wall. Could mount them on the ceiling and run cables through attic... but hell no! I just want to take this one a notch up since it's an open space and I can run whatever cables I need on the ceiling easily. What do you guys think of seatcraft seating? They have a couple 3 seater reclining theater seats that look pretty nice to me. Definitely want something that's not fake leather as I've had bad experiences with those. |
09-16-2021, 09:25 AM | #26 | |
Rep 3,241
What was able to be moved so I could have a flush wall without a boxout was the drain pipe for the kitchen sink which is directly above. The builder had it installed sticking into the room a bit without installing it flush to the poured concrete wall. So my GC moved the drain pipe to make it flush so I would have a continuous smooth wall. ETA: I also have seen some people put in drop ceilings in their HT room setups. Some of them actually don't look half bad and I seem to recall they used ceiling tiles which were designed for HT use. Going with a drop ceiling while not as nice as having the ceiling totally dry walled, will give you access to the stuff up there. The only draw back is you do lose a bit more ceiling space.
dreamingat30fps5330.00 |
09-16-2021, 09:42 AM | #27 |
Rep 3,241
Something else which hasn't been discussed here is power. Don't know how far you're going to go with this project but you should put a little thought into the power situation in the room. At the very least, I would look into having a single dedicated circuit to power the equipment you are going to use off of it. If you go with adding recessed lighting in there, you would want anything lighting related totally separate from the power being used to power your equipment. Reason being is if you plan this right, you can put in different lighting zones to allow flexibility in what lights are on and at what level. But this is achieved with dimmers which can introduce noise artifacts into the power circuit. I have I think 4 lighting zones in my room. I primarily use two settings. All on which is what you're seeing in the pics, or just running the low voltage MR16 lighting that are on the sides of the room.
You can go crazy with putting in dedicated power. I went to an extreme with mine. I have 3 dedicated 20A circuits. One feeds my Bryston 6B-ST 3 channel power amp only. The other feeds the two Velodyne subs. And the last one goes into the rack mount balanced power transformer which provides conditioned power to all the front end equipment and the Emotiva XPA-2 2 channel amp. On the other end of the two circuits that feed the Bryston and Velodyne, I have two hardwired balanced power transformers coming off a 100A subpanel I had installed for this very project. |
09-16-2021, 10:05 AM | #28 |
Rep 77
Spray the ceiling black. My cousin just did this and it looks great. Makes the room look larger.
09-16-2021, 10:10 AM | #29 |
Rep 538
Ughhhh tell me about it. Makes me miss living in TN I'm drooling over all of these setups
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
09-16-2021, 10:51 AM | #30 |
Rep 474
Drives: F36 440i GC
We went with a bit of an unconventional approach to our home theater. We chose a giant sectional sofa over theater seating because it's usually just us watching movies in this room so we wanted to be able to get really comfortable.
We went with a 77" Sony OLED and while the picture is excellent, I will agree it's a bit small for the room. I may consider upgrading to a quality screen and short throw projector in the future. We used Sonos for our sound. 2x Subs, Arc soundbar, and ceiling mounted Play:1's for surround. Not as clean as some in-wall/in-ceiling mounts, but we can take them all with us when we move.
2024 Porsche Taycan 4S
2017 Ducati Monster 821 |
09-16-2021, 10:54 AM | #31 |
Rep 5,728
Drives: 2019 M2 Competition
No basements in Cali
09-16-2021, 11:13 AM | #33 |
Rep 1,539
I did mine on a budget, since I wasn't sure if I will use it, and it turn out very very nice for the price.
- TV vs Projector : If you have a nice everyday tv, Ill go projector, they are pretty good now. 4k and hdr support, dynamic contrast for better ''blacks''. If your basement can be 100% dark, go projector. I went projector for 2 mains reason : 120'' screen , look sleek since I'm using a grey paint , on a wall ( no projector screen). no tv will get you the in/$$ ratio like a projector. * Please note that NONE of the internet video/pictures will represent a projector quality, I though projectors were bad, but the fact it play on your eye bight/dark adaptation to trick you, and interpret the contrast way higher than it is. You know, projectors black are not more black than the wall/screen. In real life with you brain interpretation, black are black, and image is amazing. I have a benQ Ht3550 DLP 4k , open box, unused, for quite cheap on newegg. - Sound System : Go right away with something that will last . 4k and atmos at least. (real speaker. Even if sound bar can simulate 360° with bouncing sound waves, sound waves is physics, and so far, nothing will replace real directional sound that physical speaker) I also got my amp for cheap, a audiophile was selling his everyday kit to upgrade. So it was almost new (2.5y). Onkyo TX-NR787. It got all the bells and whistle, 9.2 ch. I'm on a 7.1 setup right now. - Speaker : I very enjoy vintage speaker. FB is full of these, they are cheap, and sounds very very nice. - Sub : Ive salvage one on the best sub for the buck , the famous Z-5500. only the sub. 10'' , ported, with the upgraded big capacitor mods. If you can , I suggest 2 sub in diagonal. Lets say : front left, and one rear right, behind/next to the seating position) - Acoustics; I have a acoustic floor, ceiling and I had acoustic pads on my wall (not in the picture) - HTPC : this is very important, not all plug n' pay devices will give you all the experience. IMO a win10 pc is the way to go. I'm using a old pc with a GTX960 card, that will decode 4k without any drop frame. Win10 can load color .icm file for color accuracy. Also , it has a easy multichannel control. Win10 support HDR. And easy to see what kind of audio track you have. ohhh and ... heuh,, plex, torrent, pocorn, reddit stream, youtube, real netfilx, VPNs, gtaV.... Let say you have a 2ch or 5.1 ch audio track; then you set your amp so it will simulate the missing channels (mine is Dolby Surround sim) Atmos or 7.1 true HD, you set it on direct multi. (atmos, the amp will switch it automatically) I have few friends that paid someone to do a basement home theatre, and they spent 15k$+ and they are jealous of my 2000$ setup . Sound is crisp, 360°, warm, and super clear. (about 2 hours of setting) Ive used a tape for distance, and a sound level meter) Image is awesome, can't see a MAJOR drop from my 32'' HDR 4k computer monitor, with a VA pannel (va lcd = deep blacks) Last edited by oVeRdOsE.; 09-16-2021 at 11:33 AM.. |
09-16-2021, 12:20 PM | #34 |
Rep 3,241
I'll be that guy. I auditioned an Atmos system. Wasn't impressed at all. My approach is decent speakers, set up properly, and the room acoustics addressed.
For reference, the Atmos system was in the home of the owner of one of the speaker brands mentioned here. |
BMWGUYinCO4122.50 dreamingat30fps5330.00 |
09-16-2021, 12:29 PM | #35 | |
Rep 1,539
Bench test proved that beats by Dre, were very out of 'real' sound, but people like them since low freq are boosted. Atmos has nothing to do with sound quality, if the recording is good, it will be good in 1ch to xx ch. Atmos is a process. Its not individual sound track like 5.1 (6ch) or 7.1 (8ch). Its a sound track with binary instruction for the 'atmos' processor. No individual sound track, the processor will decode channel as per your #of ch in your setup. Iirc it can simulation up to 32 channel. |
09-16-2021, 12:33 PM | #36 | |
Rep 3,241
omasou2089.00 |
09-16-2021, 12:56 PM | #37 | |
Rep 1,539
Indeed it could be different since its a computer that split channels, since real 5.1 / 7.1 is most of the time a human that mix the tracks. Atmos start to be effective on 5.2.2 setups and more |
09-16-2021, 01:00 PM | #38 | |
Rep 3,241
For me, it just wasn't natural sounding. I think you have the same mindset as me. Multichannel systems should just disappear. I shouldn't be noticing that this sound comes from that speaker which was the false selling point when surround systems first hit the market. |
BMWGUYinCO4122.50 |
09-16-2021, 01:03 PM | #39 |
Rep 1,539
atmos can be fake indeed.
Have you tested the same sound track with a 5.1/7.1 file and then an atmos format ? I dont have a complete atmos setup. its 7.1 on normal, or 5.1.2 on atmos, but ultimately both files were very similar at my ears Here the test files : https://www.demolandia.net/cinema/do...hd/page-9.html Like I said , its subjective, you can always bypass atmos if you want in the amp options. |
09-16-2021, 01:21 PM | #40 | |
Rep 3,241
I have. The same movie I watched at the aforementioned home, I had watched on my system. Didn't miss any of the extra channels and the effects with Atmos. Yes, it's entirely subjective. Everything about this hobby is subjective. I prefer the sound of B&W speakers as I enjoy how they perform with mids and especially vocals. It was enough to get past that to me B&W speakers tend to be aggressive with the highs. I've tuned a lot of that out with the room treatments I've installed in my room. I remember going to one of the high end audio boutiques where the owner was raving about the new Dynaudio speakers. I listened to one of them and was...meh....especially at the price premium. Same thing with video. Some love that blown out in your face picture presentation. I prefer a more natural presentation hence why I always do something to the TVs I have with dialing in the picture settings where possible. With bypassing Atmos, sure, but then you've spent all that money putting up speakers and the extra amplification for nothing. I just think Atmos needs to mature more before someone such as me will accept it. |
oVeRdOsE.2716.00 |
09-16-2021, 01:40 PM | #41 |
Rep 3,006
I had started finishing my basement but this last storm has put me back to square one. Some lessons learned.
1. Find out where the water table is around your house!!!!!!! I'm not sure how to do this? I had ~ 6" of water in my entire basement. Prior to the power coming back on the water started to drain out of the basement through the sump. I "think" this is b/c during the storm the ground and drains were overwhelmed and once the water table started dropping below my basement the water in the basement started to drain. Any one know if this is correct? If so, I plan to build a 12" wall around my sump to stop a future flood. Yes, I should have had a battery backup and generator but got into analysis paralysis. I cannot use a water pressure backup sump b/c I'm on a well. No power, no water. 2. I "sealed" the concrete floor using DRYLOK® Natural Look Curing Membrane & Penetrating Sealer to serve as a vapor barrier and if a "little" bit of water intruded it wouldn't soak into the concrete and would dry quicker. UGL recommend this product at the time b/c the Drylok for the walls "seals" and if water pushes up from below the floor it will heave and crack. Today they offer an additional product for basement floors called DRYLOK® Floor & Wall Masonry Waterproofer. https://d3itmjxbj69sp9.cloudfront.ne...art-4-8-19.pdf 3. I sealed the concrete walls using DRYLOK® Extreme Masonry Waterproofer. 4. I used DriCore for a subfloor. This stuff is great! Unfortunately, since it was underwater the black plastic feet underneath retained water and kept the bottom side wet after the top was dry. I could pull a few and check but for ~ $2K it's not worth it for me. I've ordered the new DriCore R+ which is warmer but also 1/4" taller. Therefore, if I cannot lift the walls enough to slide it under, I'll have to get creative w/the baseplates. Walls were built on top of the DriCore. 4. I glued 2" FOAMULAR (EPS) on the walls and sealed all the joints. If you want you can build the walls and then spray foam behind them. This requires much more planning and you will need to run and inspect the wiring and pluming first. 5. I spray foamed all the joist cavities. This made a DRAMATIC improvement to the basement and whole hose warmth and lowered my heating and electric bills. Cannot recommend this too much! Prior to this my basement was very dry from water but very humid and I purchased a whole hose dehumidifier and I highly recommend one if you have humidity. The plastic on the wall and floors test showed no water vapor, so sealing the floors and walls was overkill and belt and suspenders but I never expect to see them again once finished and I don't want to worry about moisture condensing and molding down the road. https://shop.aprilaire.com/collections/dehumidifier https://www.aprilaire.com/whole-hous...del-1850-1850w The DriCore made the floor walkable during the winter in bare feet and the Fomular also made it warmer but still slightly chilly. Luckily I hadn't progressed pass framing the walls or I would have a ton more work to do. You can spend months going down the sound isolation rabbit hole but I feel what I have done plus the Roxul that I will used on the basement ceiling and walls (yes, over the Formular) will be more than enough to help w/the sound. The main things that I have learned that carry sound to the rest of the sleeping family is bass when too close to a wall and the duct work. I plan to attenuate the ducts. I have already started sealing and taping and may wrap them in that bubble insulation or just frame and Roxul, probably the latter. As for equipment. I would recommend racking all AV equipment above the water line (see #1) and all outlets higher than normal. For TVs the new Sony A80J (OLED) is at a sweet spot for price / value. It supports the Apple TV app and basic Homekit if that's important. The picture is fantastic. So much so, I wouldn't spend more for the A90J. For sound, that depend on budget. I had/have an older Proceed setup but the wiring (Transparent) is as expensive as the AV. For speakers, I love Canton but they are hard to find and as others have said speakers are very subjective. I didn't like B&W in the past but today I have a wireless/ethernet set of B&W Formations that I love!! I have the Bar, Sub and 2x Flex (rear). Yes, they are only optical do not support some of the newer formats but for what most people watch they are more than sufficient. If you're the type that needs 7.1 or 9.1 then I have no recommendations b/c I feel those are well past the point of diminishing returns. https://www.bowerswilkins.com/formation Lastly, talk w/your insurance agent; sewer and flood is a separate rider and sometimes does not cover the heaters! Luck for me my heater and dehumidifier were placed on cinder blocks and safe. HTH. Last edited by omasou; 09-16-2021 at 02:45 PM.. |
