      06-03-2020, 01:56 AM   #1
halfnhaf
Drives: bmw 645
Bmw 645 Ci won't start- help!
Dealer said my DME has corrosion. Possible to purchase a used unit and get it programmed so it communicates?! Help please!
      06-03-2020, 08:20 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
The DME is "moister proofed". If the board damaged or do you have corroded contacts on the connectors.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      06-03-2020, 08:29 PM   #3
Derekz4
Drives: BMW 640i. BMW Z4,01 Bullitt
Google bmw E63 IVM. There are many good threads on the topic. This is a common no start failure on the E63.
      06-04-2020, 02:35 AM   #4
halfnhaf
Drives: bmw 645
Corroded connections
      06-04-2020, 02:52 AM   #5
halfnhaf
Drives: bmw 645
Unit and engine harness have corrosion. Dealership says I should just trash the car. Are they right?
      06-04-2020, 08:22 AM   #6
arucano
arucano's Avatar
Was this car in a salt water flood? The ECUs are around $3K each and the plugs will have to likely be replaces as well. You could try some "jewelry" cleaner (tarnex or equivalent) on the contacts and connectors. If you can get them clean, spray on WD40 or some other form of corrosion protection.
Good luck
      06-04-2020, 10:47 AM   #7
halfnhaf
Drives: bmw 645
Good luck
No, never has has any kind of damage. I was totally confused about how that could have happened. Frustrating
      06-04-2020, 10:52 AM   #8
halfnhaf
Drives: bmw 645
Good luck
I'll give Tarnex a shot, thanks.
