View Poll Results: Do you change your own tires? | |||
Yes | 30 | 62.50% | |
No | 17 | 35.42% | |
Sometimes/Depends | 1 | 2.08% | |
Voters: 48. You may not vote on this poll |
10-29-2022, 01:30 PM | #45 | |
Rep 787
If lube becomes a consideration because the threads are F'd or were clearly too tight last time, you probably won't be getting factory spec fastener tension (which is a product of torque and surface friction) on them ever again anyway. The threads will drag and gall and likely register rated torque long before proper fastener tension is achieved. The tension is important, not just torque. While on the subject, don't use an air wrench to put them back on, use a torque wrench. I've had lugs come back from a reputable tire shop that were at least 200% over torqued. I had to stand on the end of a 2' breaker bar to get them off an hour after I got home to properly rotate them after a flat repair. In retrospect, I never saw a torque wrench used at that tire shop. Last edited by chad86tsi; 10-29-2022 at 01:40 PM.. |
10-29-2022, 01:36 PM | #46 | ||
Rep 1,446
Efthreeoh17309.00 |
10-29-2022, 01:39 PM | #47 |
sportscars only
3245
Rep 3,195
Thanks for all the new posts. I'll try to answer as best as I can:
I don't think that I need a new impact wrench. Mine does the job fine twice every year. It is only when some idiot overtightened that I run into this prb. No matter what electric wrench I get, an air gun will always be>>>>>>>>>>>> so if some fool at the shop doesn't care and overtightens, I'm screwed anyway. (I live in a condo but even if I had my own garage I'm not gonna bother w getting an air gun, that's way overkill for me.) My wrench is rated at 350lb-ft for tightening and loosening. Like I said, I never had any prbs save for when above happens. I appreciate the advice on anti-seize but I think that's why subconsciously I never used it. I adhere to the KISS principle, so if I can do it w less stuff and complication, I will. As this thread developed, I realized that I didn't do anything wrong really (save for forgetting to remind those guys when they did my rear brake job). I need to be damn vigilant and remind those guys whenever the wheel comes off. Sigh, what a pita, I forget this one time so they told the Hulk to tighten my rear wheels. I do have a drill w industrial scrubber attachments, so tx to the guy(s) who reminded me to use that: I will add that to my tire changing regime. I dunno what else needs to be said now cuz I think I will need to find a professional on Monday and hopefully this will be the LAST time. As long as I remember to tell those careless ppl about my tq setting, I *should* be ok from now on. Lesson learned. Tx again guys, you are pros.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
chad86tsi1605.00 |
10-29-2022, 04:54 PM | #48 |
The Seeker
13863
Rep 3,323
The last oil change/tire rotation I got at Honda on the RDX left me with 2 lug nuts on my driver's side rear that were under-torqued. I fixed the issue and called them to let them know, but no harm, no foul (until someone gets hurt).
Efthreeoh17309.00 |
10-29-2022, 09:11 PM | #49 |
Rep 7,298
They do, which is another reason why I don’t recommend lubricating threads. If you do it on your own, better make sure you never take it to a shop or dealer and they have to remove the wheel. It’ll be even harder to get off.
10-30-2022, 01:16 AM | #50 |
2JZ-GTE
3042
Rep 3,996
Always use the air wrench for the final tightening.
10-30-2022, 03:46 PM | #51 | |
Rep 3,470
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
10-30-2022, 04:02 PM | #52 | |
sportscars only
3245
Rep 3,195
StanDiego6248.50 |
10-30-2022, 05:18 PM | #53 |
Rep 3,241
I've never had issues knocking loose lug nuts/bolts. I still use air tools and have the air pressure dialed all the way up to the max at 150 PSI. Don't use anti-seize on any of the lug nuts/bolts. I tighten down to the lowest power setting on my impact and then follow up with a torque wrench to tighten to spec.
Have to say, I did bring my Toyota daily to Walmart for them to mount and balance tires I bought from Tire Rack. Was surprised they paid close attention to what they were doing with putting the tire/wheels back on the car. Watched them the entire time. Aside from them putting anti-seize on the wheel studs, they tightened down the lug nuts and then finished the tightening with a torque wrench. They even followed the proper torque sequence. |
chad86tsi1605.00 |
10-30-2022, 05:54 PM | #54 |
1Addict
3233
Rep 7,894
Yep I always take my wheels directly to the shop with my other car.
Last time I tookt hem off for a DIY job they were torqued so excessively I thought I would have to replace the hubs. Put a 3' cheater bar on my breaker and snapped my socket extender. Learned my lesson forever. Also helps to put antiseize on the hub bore, prevents them getting stuck if you don't touch them for a a while. Key here is the hub face/lip but not the lugs or threads.
10-31-2022, 01:44 AM | #55 |
Rep 7,298
You should not apply anti-seize on the hub or wheel mounting faces. You need friction here. The hub lip is the only acceptable place for anti-seize. Honestly, I don't understand why people put this shit on everything. It's messy as hell and you won't have a problem anyway. If manufacturers wanted anti-seize everywhere they would be recommending it.
///MPhatic13862.50 |
10-31-2022, 06:50 AM | #56 | |
BMW Owner Since 1971
2257
Rep 1,406
10-31-2022, 08:40 AM | #57 | |
1Addict
3233
Rep 7,894
________4158.50 |
10-31-2022, 09:54 AM | #58 |
Rep 1,795
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Nowhere is there a recommendation for putting anything on lug nuts/wheel bolts/wheel studs. Everywhere it is recommended threads should be clean and dry.
Example:.https://www.tirerack.com/tires/tiret...jsp?techid=107 "Ensure the stud or bolt threads are clean and dry with no oil, grease or any other kind of lubrication applied to the wheel's hardware." "Note: It is important NOT to lubricate hardware threads or seats. The friction torque is measured against should come from the hardware seats. Lubricating hardware threads and seats alters the friction generated at the lug seat, which could result in inaccurate torque application." |
10-31-2022, 11:34 AM | #59 | |
Rep 7,298
10-31-2022, 07:35 PM | #61 |
sportscars only
3245
Rep 3,195
I think this is right but just in case:
so the door jamb tire pressure label says 36psi front and 42 rear, but that's was for my staggered 225/255 set...now that my winters are a square set, I assume that the psi is the same throughout @36psi? What takes precedence, I always thought it depends on the tire size?
10-31-2022, 08:48 PM | #62 | |
Rep 787
10-31-2022, 09:07 PM | #63 |
________
4159
Rep 2,301
Agree on anti-seize on the rotor hat surface/hub lip where the wheel mounts. Sometimes it’s the only way to remove the wheel after a few seasons.
Against anti-seize on the bolts. You don’t want these backing out. Also on the camp of “which friction does the rotor need with the wheel” with 5 bolts tightened with 120Nm… |
10-31-2022, 09:10 PM | #64 | |
________
4159
Rep 2,301
I believe so, if I remember. These pressures are set based on a number of factors, load being the biggest one, but also traction and temperature. You’re totally safe with 36 all around, that’s what I do (I’m staggered). |
10-31-2022, 09:17 PM | #65 | ||
sportscars only
3245
Rep 3,195
Confused about your last para, you're staggered but have the same psi? That shouldn't be right, no?
10-31-2022, 10:09 PM | #66 | |
Darth ZEDer
6249
Rep 1,105
Drives: 2022 BMW Z4 sDrive3.0
