View Poll Results: Do you change your own tires? | |||
Yes | 30 | 62.50% | |
No | 17 | 35.42% | |
Sometimes/Depends | 1 | 2.08% | |
Voters: 48. You may not vote on this poll |
10-28-2022, 06:17 PM | #1 |
sportscars only
3245
Rep 3,195
frustrating tire changes
Every now and then, when I DIY, I encounter some disgustingly STUCK lug bolt(s) that even my impact wrench cannot dislodge, so I have to scramble over to a mechanic to have it professionally removed.
Maybe I'm partly to blame because I just change my tires, I don't scrub anything or put whatever grease or whatever cuz I don't bother/don't think it matters much. However, if you have any pointers, please lemme know. I'm thinking the main reason they are stuck is because the shop just over-tightened the bolts (even though I ALWAYS tell them the tq spec and that I DIY, they just don't care argh). My wheels were last handled by a shop who changed all 4 tires, but before I go off on them, my 2 front wheels were perfectly fine and I removed them w ease, but my 2 rear ones were stuck, so I would assume they put them all on properly and it has something to do w the moving wheels vs non-moving, unless they got 2 separate guys putting back the wheels? What do you think is more likely? How many of you guys change your own tires and can give me any advice? Maybe sometimes the bolts being stuck is unavoidable?
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
10-28-2022, 07:29 PM | #2 |
BMW Owner Since 1971
2257
Rep 1,406
I remove and install my own wheels but—unless it's on my BMW bikes—I do not have the equipment to change my own tires.
10-28-2022, 07:43 PM | #3 |
Rep 328
When I change my wheels I put a some anti seize about the size of an eraser head on the tip of the bolt. Classic star tightening pattern. Torque to spec and check after 50 miles. I have never had a problem removing.
2023 M4 Comp
Dravit Grey Metallic |
tranquility3244.50 |
10-28-2022, 07:48 PM | #4 | |
sportscars only
3245
Rep 3,195
I don't wanna buy the wrong thing and find out afterwards it's a loosener and my bolts go flying off LOL. What are you using exactly? Tx.
10-28-2022, 07:52 PM | #5 | ||
Rep 1,446
tranquility3244.50 DrFerry6728.50 |
10-28-2022, 08:05 PM | #6 |
Rep 328
It's such a small amount it pretty much stays right near the tip. It won't loosen. I have never had an issue. The key is tightening the bolts correctly by the star pattern. I am anal when it comes to the correct torque. I check every couple of months.
2023 M4 Comp
10-28-2022, 08:10 PM | #7 |
sportscars only
3245
Rep 3,195
Ok, so what causes the seizing/my bolts getting stuck? I just assume it's something happening to the threads? Should the grease thing go there too? I'm confuse why only the tip, is that where the seizing usually occurs?
10-28-2022, 08:17 PM | #8 |
Rep 781
Just to add to these good tips, remove your wheels from the car and take them separately for a tire change, then bring them back put the wheels on yourself.
Lug nuts and studs need to be cleaned every now and then, a wire wheel and an old tooth brush with some brake cleaner, the only stuck nuts or studs I have encountered were due to rust or lack of proper maintenance. You can't achieve a proper torque if the threads are gooed up with old grease and dirt.
2008 E86 M coupe
tranquility3244.50 spammysammich1583.50 Efthreeoh17313.50 DrFerry6728.50 Mavus2029.50 Pauldunlop13425.00 Kowalski20111172.00 M5Rick60071.00 |
10-28-2022, 08:21 PM | #9 | |
Rep 781
If in doubt replace them, they're not expensive.
2008 E86 M coupe
10-28-2022, 08:56 PM | #10 | |
Rep 2,310
Drives: 9Y0 Cayenne S
10-28-2022, 08:59 PM | #11 | |
Rep 1,446
10-28-2022, 09:10 PM | #12 |
sportscars only
3245
Rep 3,195
Silly question, where do you buy your lug bolts? I bought my 1st replacement from BMW, but wondering if can get better quality/cheaper/etc?
10-28-2022, 09:57 PM | #13 | |
Rep 7,298
Get a 2 ft or 0.5m+ breaker bar and use that. |
chassis6552.50 tranquility3244.50 spammysammich1583.50 Efthreeoh17313.50 Mavus2029.50 3798j11413.50 Kowalski20111172.00 Wolf 3352340.50 |
10-28-2022, 10:04 PM | #14 | |
________
4159
Rep 2,301
Never even heard of a bolt getting stuck. If you take your car to a shop, loosen the bolts and tighten them to spec yourself. They should actually feel somewhat “loose” when you need them off next time, compared to what shops/non-torque wrench folks do. People usually over-tighten bolts, and that is why we use a torque-wrench. Funny how most people think a torque wrench is used to TIGHTEN more… maybe because of the name of the tool lol |
10-28-2022, 10:04 PM | #15 |
Rep 2,310
10-28-2022, 10:10 PM | #16 | |
Rep 7,298
________4158.50 tranquility3244.50 |
10-28-2022, 10:51 PM | #17 | |
sportscars only
3245
Rep 3,195
Should I just keep at it w my electric torque wrench? I don't wanna buy more stuff (tq bar). I'm not sure if I'll be damaging anything?
10-28-2022, 11:07 PM | #18 |
________
4159
Rep 2,301
You don’t have a 2-feet bar? It’s like 15 bucks, no?
Be careful with it though, if a bolt is really stuck this thing might shear its head off. Better to hit the bolt as hard as you can with a mallet a few times before trying to taking it off. |
10-28-2022, 11:12 PM | #19 | |
sportscars only
3245
Rep 3,195
I just checked my bills, @#$#$!$ it wasn't when I had my tires done, but afterwards when I did my rear brakes. Just cuz I forgot to remind them they freaking overtorqued it. Now that explains why my fronts were fine and my rears were not.
10-28-2022, 11:22 PM | #20 | |
Rep 7,298
10-28-2022, 11:38 PM | #21 |
sportscars only
3245
Rep 3,195
My impact wrench plugs into a wall and apparently maxes at 350lb-ft...they couldn't have possibly tightened over that, right? I'm confused unless my wrench's specs are wrong, how the hell can 350lb-ft of power from my wrench not be enough to remove those bolts?
10-29-2022, 12:19 AM | #22 |
Darth ZEDer
6249
Rep 1,105
Drives: 2022 BMW Z4 sDrive3.0
I've got one of those but feel much safer using an electric or battery powered impact wrench to loosen (not tighten), believe I'm less likely to break off a bolt.
