11-30-2021, 04:19 PM | #1 |
Rep 12
Can't locate the other USB
I have a 2016 640d Gran Coupe in the UK. I need to update the maps and the usb under the armrest isn't the one I need to use. I can't find any other one. There is none where the cupholders are and none in, around, or underneath the glovebox.
Does it have one? I'm sure others have managed to update their maps, so there has to be a way. Thanks. Last edited by TSV; 11-30-2021 at 04:33 PM.. |
11-30-2021, 04:33 PM | #2 | |
Scott
36
Rep 97
Drives: BMW 640i
Scott
11-30-2021, 05:00 PM | #3 | |
Rep 12
Cheers anyway. Last edited by TSV; 11-30-2021 at 05:12 PM.. |
12-01-2021, 11:58 PM | #6 | |
Rep 7,477
Hopefully someone with a RHD model will chime in. Those of us with LHD models & early builds (pre facelift) w/NBT ID4 have the USB in the roof of the glovebox.
If you have a RHD model, the steering wheel is located on the side of the car where the DATA/USB is located…so I’ve never heard (or don’t remember) any RHD owners mention where the USB port is located. Our owners manual (LHD) tells us where it is located…is this info missing in the RHD owners manual? EDIT: did a search for previous threads on this topic…below are some quotes from other forum members from Europe (RHD & diesel) owners Quote:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-02-2021 at 01:19 AM.. |
12-03-2021, 10:43 AM | #9 |
Rep 57
...... as your car is a 2016 I'm assuming it's an LCI therefore it's definitely the one by the cup holders under the flap at the front of the centre console - I've update my maps using that port a number of times
12-04-2021, 09:51 PM | #12 | |
Rep 285
12-22-2021, 12:59 PM | #13 |
Rep 10
Is there a way to get free map upgrades?
12-22-2021, 03:45 PM | #14 |
Rep 31
Not free, but $75 for lifetime updates is pretty good. I used this source when I updated my maps about a year ago. No glitches!
https://bimmernavupdates.com/shop/bmw-6-series/ |
01-12-2022, 10:14 AM | #16 | ||
Rep 33
BmwpartsBP27.00 JamxnickzBMW0.00 |
02-25-2023, 02:28 PM | #17 |
CELLO11
Rep 11
I had several BMW in the past. According my experience the CIC systems (up to 2013) have the USB for map and system update in the glove box opposite to the driver seat.
The newer NBT systems (after 2014) do NOT have any USB slot on the glove box, but there the update is done via the USB in the central compartment, the same USB used for playing MP3 via memory stick. |
