04-25-2020, 04:55 PM | #1 |
Rep 32
replacing of armrest lock - F12
Does anyone have experience changing the armrest lock on a F12 or similar?
I went to the stealer today... but I was quoted $750US to replace.. seem it bit outlandish to me. I have found the actual lock part available on line for $90. I am very temped to order and replace myself. https://www.realoem.com/bmw/enUS/sho...69#51169240213 How hard can this be?? the panels work perfectly... However, the lock is broken, thus I cannot lock it. Anyone?? |
04-25-2020, 07:37 PM | #2 |
Rep 7,475
There are instructions to change it on the TIS website.
Click this link: https://www.newtis.info/tisv2/a/en/ ...type in the last 7 digit of your VIN (or select appropriate model etc)...then type something appropriate in the search box like “ replace lock cylinder in center armrest”
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-25-2020 at 07:46 PM.. |
04-26-2020, 12:46 PM | #6 | ||
Rep 7,475
Take note to any PRELIMINARY links given in the instructions which shows how to remove things that may need to come off prior to the armrest covers.
04-27-2020, 07:30 AM | #8 | |
Rep 7,475
That link provides two "PRELIMINARY TASKS" that are required: Necessary preliminary tasks:
Then you: Open storage compartment, if necessary. Lever out and remove the closure cover (1) with special tool 00 9 325 . Release left and right bolts (2) on centre armrest cover (1). Tightening torque 51 16 13AZ. Release screws (1) on back of centre armrest cover (2). Tightening torque 51 16 13AZ. Raise the rear centre armrest cover (2) and pull back slightly. Installation note: Correctly feed the retaining lugs (1) into the centre console support. At this point in the instructions...it appears the two covers come off as a unit...and may be intended to be replaced that way. It may take some ingenuity at this point to figure out how to separate the two covers. Going to the part database to verify the above assumption...it does appear that the covers are engineered/designed as a single unit...thus taking them apart wasn't intended...so to do it would require some ingenuity and probably patients. https://bimmercat.com/bmw/en/search/...iX/USA/51_8169
04-30-2020, 01:29 PM | #11 |
Rep 32
"borrowing" my thread back.... I am stuck!
I purchased a new lock and I figured out how to remove the chrome trim around the lock. I have even recoded the new lock... I cannot get the old lock cylinder out of the console. I had to stop since I already broke a piece of the cylinder by trying to pry it out. I have the key inserted when trying to get it out.. the instruction suggest that it will come out with a screwdriver pry. What am I missing? thanks in advance |
04-30-2020, 01:46 PM | #12 | |
Rep 1,824
04-30-2020, 03:52 PM | #13 |
Rep 32
yes.. thats the same link i was looking at.
https://www.newtis.info/tisv2/a/en/f...soles/F3HzRPPn has anyone done this? I am afraid to damage the overall lock by leveraging the cylinder. I have already broken part of the cylinder.. |
05-03-2020, 03:17 AM | #14 |
Rep 86
In order to remove the entire central console newtis instructions didnt mentioned about the prying the side cover to access 4 screws.
The console spring are mounted at the rear end. Hence this save me time to remove the entire console. Does anyone knows the spring part nos? https://www.newtis.info/tisv2/a/en/f...f22/1VnXmpdI1Z Last edited by blackbmw2018; 05-22-2020 at 09:20 PM.. Reason: . |
04-05-2022, 07:01 PM | #15 | |
Rep 7
armrest removal 2018 m6
Hey if you dont mind letting me know the entire process of removing the armrest that would be amazing. I just ordered a whole new arm rest from the dealer and will arrive soon . I wondering what the steps are and if you completly figured it out |
