05-05-2020, 08:17 AM | #1 |
Mad Fiddler
792
Rep 991
Brakes?
Took a drive North yesterday and ended up in San Luis Obispo - about 180 miles from home. I had noticed the dreaded shudder when applying the brakes between 60 and about 80. My head immediately goes ‘warped rotors’ but I hear this is rare. I think it’s probably uneven wear or deposits or something like that.
I suppose I need to look for rotors and Maybe pads. Was told yesterday that my front pads still had 8mm. The dealer replaced my rear pads under my prepaid service agreement several months ago, so I assume that the front rotors may be the culprit(s). Should I even ask BMW if they’ll cover this? The car has about 40k on the clock and three months left on the factory warranty. I’ve read that they don’t usually cover this. All that being said, if it needs to be done, I of course will not throw an extra grand at the dealer. I know a few indies that are quite good and usually about 60% of the price. Do I go with after market rotors and pads? OEM? I would appreciate any and all advice from y’all. Thanks in advance! |
05-05-2020, 10:11 AM | #2 |
Rep 738
First you should take it out on a empty road and do 5 or 6 hard slow downs from say 60 mph to 20 mph to heat everything up and clean the rotors. Don't engage ABS. Keep doing it until you smell the brakes and then cruise for 10 miles or so to let everything cool down. Don't stop with the brakes applied while they are still hot. That maybe all you need to do.
05-05-2020, 10:24 AM | #3 | |
Mad Fiddler
792
Rep 991
05-05-2020, 07:37 PM | #4 |
Kraut Driver
59
Rep 624
Drives: 2014 650i GC/2011 335is DCT
I did powerstop performance pads and rotors and they've been awesome. Was around $600 total and I've had no issues and the coating has held up great through two winters.
tpsc3crt2.00 |
11-30-2020, 01:58 PM | #7 | |
Mad Fiddler
792
Rep 991
When (if) I do have to replace the rotors - should I have the car that long - I think I would go for Zimmerman as they supply BMW with brake parts. The only other thing I would ten to make sure of, is that I got two-piece rotors, like the car came with from the factory. |
