      12-27-2018, 05:42 PM   #45
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Originally Posted by powahousealex View Post
do you feel a better pull with the new intakes installed?did you change to stage 2 tune yet?
I can't tell if it pulls any harder. Probably due to the tune (Stage 1) or my butt dyno is just not sensitive enough. Might be easier to tell if the car was stock. I can hear the intake induction noise & the turbo spool is more noticeable.
Catless DP & Stage 2 will be next month....
      12-30-2018, 04:58 PM   #46
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
RK Autowerks induction noise
      01-02-2019, 07:04 PM   #47
Flo1989
Flo1989's Avatar
342
Drives: M6 Gran Coupe
I didn't even know you had this progressive build on the forums. Very useful information you've placed in here so far. Excited to see what's yet to come!
      01-03-2019, 09:44 AM   #48
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Thanks. Its getting close to completion, then again, does it ever end...
      01-03-2019, 10:04 AM   #49
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
800GSM microfiber towel.
Lanka - great product for touch up paint cleanup. Best to use a t-shirt or any cloth without long fibers. The goal is to remove the paint on top of the clear coat but not inside the chip.
https://www.amazon.com/Langka-LANGKA...VT71W67G5JMHNN
Key fob case replacement
How to replace: I did have to cut open the original but the new one simply clamps shut
CR2450 key fob batteries
https://www.amazon.com/Sony-CR2450-L...SBENYNXKRG5ZN9
CTEK 40-206 MXS 5.0-12 Volt Battery Charger My previous vehicle (E60 M5) was on the original battery for 8 years. Not that it was causing issues at the 8 yr mark, just though it was time to replace. Vehicle is plugged in (via engine bay) every day.
https://www.amazon.com/CTEK-40-206-5..._ob_title_auto
For those who rather have a BMW sticker vs CTEK.
https://www.amazon.com/BMW-4-3-Batte.../dp/B00L1JUUVS
https://www.shopbmwusa.com/PRODUCT/4...ATTERY-CHARGER
      01-04-2019, 10:01 AM   #50
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Fine Line Painting Pen - good for applying touch up paints. Not sure how well it works on vertical faces. Bought one but haven't used it.
https://www.amazon.com/gp/product/B0...a89a7efb5d63b9
Demo vid: Fast forward to 5:25
Fast forward to 1:00
Fast forward to 2:04
Detail Paint Brush Set - what I have been using. All tips come to a perfect point. Size 0, 00 or 000 preferred
1. https://www.amazon.com/MEEDEN-Detail...01D9W6SNS&th=1
2. https://www.amazon.com/Detail-Miniat...1HWCAGQQ&psc=1
Eyeliner brush
1. https://www.amazon.com/KINGMAS-Dispo...0DW2Z9JK&psc=1
ts-m516.50
      01-13-2019, 01:59 PM   #51
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Orange County Festival of Speed - https://ocfestivalofspeed.com/
Great event to attend, highly recommended.
Nice to see super & hyper cars taken on the track. I prefer to see these vehicles in motion vs stationary...
Video of the event:
Flo1989342.00
      01-13-2019, 04:42 PM   #52
dclin
Drives: FD3S
Nice! Thanks for sharing!
      01-14-2019, 08:51 AM   #53
xxTHIR13ENxx
So awesome.
Thanks, indeed!
      06-14-2019, 10:21 PM   #54
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Burger Tuning Pedal Tuner
https://www.burgertuning.com/products/bms-pedal-tuner
Though this device does not add horsepower, its a great mod to have.
Had Sprint Booster V2 (E60 M5) which is also a great device. SB costs more & you have to make sure you get a model that works for your car.
BMS has 1 device that supports all BMW models & its $100 cheaper vs SB V3. I do prefer the small size of SB.
Stage 1 tune > Comfort mode > Stage 3 red:
pressing the pedal down 1/4 of an inch feels like Sport + w/ the pedal half way down.
Torx 30 required to remove the pedal for installation.
Plug that goes to the pedal only attaches 1 way.
The other plug can go in both ways & w/ my luck I got it wrong the 1st try.
The controller will not light up & you get a ton or errors in iDrive !@#$%^
You will need a scan tool or ISTA-D (what I used) to clear the errors.
Installation & calibration video
      06-16-2019, 04:46 PM   #55
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
VViViD Dark Black headlight tint upper & lower section
3M Knifeless Tape - Design Line
Rubber Squeegee
https://www.amazon.com/FOSHIO-Squeeg...MFMPZ18AF0YEJR
2 coats of CarPro CQuartz UK 3.0 & 2 coats of CarPro Gliss V2
VViViD Smoke Black tail light & reflector tint
Wide angle mirror. Sneaky cops always try to pace while in my blind spot.
      06-16-2019, 10:49 PM   #56
longnvu
Drives: E90 E92 E60 F30
Can you share the link to the exhaust tips?
      06-17-2019, 01:12 PM   #57
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Still out of stock so a product link doesn't exist.
Here is another company that sells exhaust tips. All carbon fiber though.
Black Straight cut: https://xxiituning.com/collections/b...e-exhaust-tips
Steele Straight cut: https://xxiituning.com/collections/b...e-exhaust-tips
Burnt|Blue Straight cut: https://xxiituning.com/collections/b...e-exhaust-tips
Angle cut: https://xxiituning.com/collections/b...29257528279104
Haven't purchased anything from them. Ask for specific specs & post here if you want.
Specs:
Inner diameter of the inlet (this is very important to get right) - Ask for it in MM not inches. Should be 69MM to 70MM
I used a metric ruler instead of a caliper & mine was 68MM outer diameter. You can also see how the piping shrinks & curves (terrible design) so you can only push the tip back up to a certain point.
Length of the tips - this varies depending on how it clamps. This is also important so you don't end up with tips that stick out too much
Outer diameter - 101MM = 4". Mine is 89MM or 3.5". This becomes important on certain types of diffusers.
ts-m516.50
      06-19-2019, 07:14 AM   #58
ts-m5
Drives: F82 M4 -> F06 M6 -> F90 M5
Straight cut: https://xxiituning.com/collections/f...25454826487872
Angle cut: https://xxiituning.com/collections/f...25465536380992
Specs:
[IMG]https://i.postimg.cc/bvzfh9w0/M6-com...on-exhaust.jpg[/IMG]
Outer diameter - 101MM = 4". Mine is 91MM or 92MM or 3.5". This becomes important on certain types of diffusers.
Thanks for the xxii link.
I currently have the straight cut rolled end stainless steel exhaust tips in black chrome from Bimmian.
Now I'm kind of contemplating on the slant cut rolled end stainless steel exhaust tips that xxii has. These almost seem to be same as the BMS tips I had on M4 I used to own. xxii told me the inlet diameter is 70mm, outer diameter 97mm, length 142mm. Inlet diameter seems to be right but I'm kind of worried about the shrinking diameter and curve of M6 exhaust pipe...as you have pointed out. Outer diameter of 97mm seem oversized for my diffuser as well... I'll have to do some measuring...
      06-19-2019, 09:39 AM   #59
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Here you go. Not from where I purchased mine but it looks identical to what I have. I used blue Loctite on the threads though not sure if it was necessary.
https://bimmian.com/stainless-exhaus...-any-bmw-pair/
      06-19-2019, 10:04 AM   #60
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Thanks for mentioning Bimmian. I didn't know they sell those tips.
The slant cut tip looks good & seems to be a slip on version like OEM. I share the same OD size concerns if you have a particular type of diffuser.
Mine are:
136MM length
69MM ID
89MM OD.
(69MM inner diameter tips & 68MM outer diameter muffler tips) barely has any gap.
With my diffuser, the most I can go is 91MM OD otherwise I would have to cut this area. The tip is about 4-5MM away from touching.
The left tip is pushed all the way back so an extra 7MM would still look good. Wont stick out too much.
      06-27-2019, 10:50 PM   #61
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Seller pricing error = impulse buy (couldn't resist)
https://www.amazon.com/AutoTecknic-V.../dp/B01GC1JVPA
Sprayed w/ glossy clear + 3 coats CarPro CQuartz UK 3.0
DEI Heat barrier
https://designengineering.com/produc...ds-reflectors/
///M badge $10. deformed within 8 miles
Hopefully this doesn't happen
      06-28-2019, 10:51 AM   #62
Flo1989
Flo1989's Avatar
342
As always, your car is lookin' sick and great attention to detail, my friend! I also plan to lightly tint my tail lights as it's a bit too much red for me.
      06-28-2019, 05:01 PM   #63
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Appreciate that
Your tail lights are in much better condition than mine. Yours look like its made of glass.
A few things to consider. Difficult to get that super smooth finish with vinyl tint. Doesn't take much to scratch it. I even soaked the felt of the squeegee in distilled water & baby shampoo to reduce friction.
A few coats of ceramic coating will definitely help put the gloss back.
      07-03-2019, 11:26 AM   #64
xxTHIR13ENxx
Awesome!
Can I have your old cover? It seems mine has all the little tabs broken. It stays in place, but you can lift it like it's not connected to anything...
      07-03-2019, 01:23 PM   #65
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Originally Posted by xxTHIR13ENxx View Post
Awesome!
Sorry, I'm hanging on to it. I just had it painted Silverstone II.
Can you post pics of the back side of your cover? It sounds like you are missing these rubber inserts.
Part #2 from here: https://www.realoem.com/bmw/enUS/sho...67#13717843155
      07-03-2019, 01:31 PM   #66
xxTHIR13ENxx
That is very possible.
I'll take a look at it this weekend and see if that's the case. Easy fix if it is!
Thanks, man.
- Leo.
