      06-17-2021, 04:23 AM   #1
Bigjule1111
air conditioner not cooling
hello gents ..like the title states ..my 14 f06 all of a sudden, the air doesn't feel very cold ..was thinking of charging the unit first before i take it to my local indie shop .. so my question is , is this straight foward or is there any other thing i need to do besides connecting on the low side ? thanks
      06-17-2021, 05:08 AM   #2
Challengemaster
Drives: BMW 640d Coupé
I'd take it to somewhere that will leak test the system before just adding more refrigerant in there. If you add more in and it's leaking then you're just wasting money.
      06-17-2021, 03:43 PM   #3
Bigjule1111
i already have a can that was sitting in the garage..just want to b certain that it's a straight foward thing and not any additional steps that need to b taken
      06-17-2021, 10:15 PM   #4
AccordTR
AccordTR's Avatar
If that can is red tek you better think twice. Red tek is refined propane and once it's in the ac system almost no shop will service you ac system ever again. It's extremely flammable. Hopefully it's 134a?
M Sports Edition
Carbon Wing
Carbon Front Splitters
Carbon Rear Diffuser
Carbon Grilles
CPG intakes
Arm catless downpipes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-18-2021, 12:09 AM   #5
Bigjule1111
it's definitely 134a but i was reading about the 6 series needs to have the right intake port removed. not sure what this means
      06-18-2021, 07:00 AM   #6
AccordTR
AccordTR's Avatar
I have had my car charged a couple times, these cars are notorious for ac leaks. All my guy did was vacuum out the system to remove any moisture, then connected to the high and low side nipples.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-18-2021, 07:10 AM   #7
Bigjule1111
they connected through both sides the high and low I thought it was only the low side you connect through
      06-18-2021, 07:19 AM   #8
AccordTR
AccordTR's Avatar
Yep high and low every time I've had it recharged. In these cars both are on the passenger front side
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-18-2021, 07:37 AM   #9
Bigjule1111
oh.. so what connects on the high side ? I've done this on my other vehicles that I've owned ..it's been awhile but i never connected anything on the high side .. but keep in mind ..I'm far from a HVAC guy or a mechanic..and thanks for your input
      06-18-2021, 07:41 AM   #10
AccordTR
AccordTR's Avatar
Your recharge gauge should have 3 hoses/nipples. 1 goes to the high side, 1 goes to the low side and then the 3rd attaches to your r134a can/source. Maybe your kit has a different gauge than the 'professional' ones??
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-18-2021, 07:55 AM   #11
Bigjule1111
that's exactly what it is .i dont have a professional kit ..just a can from my local pep boys that i had sitting around in the garage
      06-18-2021, 07:59 AM   #12
AccordTR
AccordTR's Avatar
Gotcha. The gauges are about $100 on Amazon. I was warned to not just attach to the high side on this car by the ac guy. Not sure why, just what he mentioned when he was doing it. I'm sure you can just attach and fill with r134a on the one side. Not sure if it effects the system thou long term?
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-18-2021, 08:01 AM   #13
Bigjule1111
i believe if u attach hose on the high side the pressure goes back into the can and can explode .. i believe this is the case ..also this is what I dug up about the intake port
      06-18-2021, 08:02 AM   #14
Bigjule1111
here the info
      06-18-2021, 08:03 AM   #15
AccordTR
AccordTR's Avatar
That would make sense. I believe also moisture can build up in the low side and cause issues.
Correct in pic. Those are the high and low ports.I have aftermarket intakes but the factory intake would definitely be in the way.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-18-2021, 10:51 PM   #16
Bigjule1111
not sure what u mean it would b in the way ? the low side it's pretty much easy to get too it seems ..going to try recharge tomorrow morning.. heres a pic
      06-18-2021, 10:53 PM   #17
Bigjule1111
      06-19-2021, 02:51 AM   #18
AccordTR
AccordTR's Avatar
Sorry I meant if you want to access both high and low.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-19-2021, 09:19 AM   #19
Bigjule1111
looks like both diagrams that i found online is telling me the 1 in the front of the vehicle is the low side ..but i tried connecting the ac pro hose to that one and it won't fit ..it does fit on the connection that's on the back of the engine bay ..same side ... is it different for a 640 than a 650? i know they made these connections dummy proof but just want to make sure I'm hooked up on the low side. thanks
      06-19-2021, 09:22 AM   #20
AccordTR
AccordTR's Avatar
The kit will only connect to the one under the intake. So if your going to use that kit you'll need to attach there. 650/640 is the same.
M Sports Edition
Carbon Wing
Carbon Grilles
CPG intakes
Arm charge pipes
Bootmod3 Stage 2
3.5 Tmaps
xHP Stage 3
      06-19-2021, 09:38 AM   #21
Bigjule1111
it connects to this one . the 1 on the back ..but online it tell me is the one near the front passenger headlamp
      06-19-2021, 09:39 AM   #22
Bigjule1111
this one
