      06-02-2020, 08:33 AM   #1
Notsip
Drives: BMW 650i
Rear Window Issues
I have recently purchased a 2007 650i convertible and having issues with the rear window. When I unlock the car with remote the rear window lowers approx 1 inch. When I try to put the window back up it won't go up. Also every time I unlock the car it goes down another inch or so. The window will lower with the button but will not go back up unless I lower the top and put back up again. I have already replaced the battery and that didn't help with the issue. This issue is sometimes intermittent. Any ideas what the issue may be. Have had to a indy and they believed it was from the battery and trunk latch so they replaced both and that did not resolve the issue.
      06-02-2020, 12:51 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
have you tried re-sync-ing the windows?
https://www.newtis.info/tisv2/a/en/f...lator/1LKsK9oT
If it works OK with the top down, it is likely the anti-trap sensor problem
https://www.newtis.info/tisv2/a/en/f...i-cab/B2CG0jAw
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      06-02-2020, 03:18 PM   #3
Notsip
Drives: BMW 650i
I will try that!!
Thank you!!!
      06-02-2020, 03:32 PM   #4
arucano
arucano's Avatar
yep. I added some more info above Good luck
      06-02-2020, 04:46 PM   #5
Notsip
Drives: BMW 650i
Thank you!!!
      06-02-2020, 06:16 PM   #6
arucano
arucano's Avatar
