XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      05-29-2020, 01:32 PM   #1
Teutonic
Teutonic's Avatar
ZF 8AT Transmission Fluid Questions
My E84 xDrive28i is at the 95.000 km mark and I would like to change the fluid. BMW sells a kit, however the transmission fluid in it is BMW brand, not the OEM ZF Lifeguard. I know that the transmission is extremely particular about the fluid.
  • Is the BMW fluid just the ZF under a different label? Or is it merely something similar?
  • If it’s not the same, is BMW's fluid still okay to use?
  • Where can I find the ZF fluid here in Canada?
I would like to get some input. Maybe some BMW techs on this forum can share their thoughts?
Thank you kindly!
      05-30-2020, 12:39 AM   #2
andino
Drives: F31 328i xdrive
I bought the zf fluid as part of a kit from fcpeuro. But there's also a liquimoly alternative which some users on the f3x forum have found to work just fine as well.
BMW's fluid is likely just rebranded ZF fluid fwiw. I also don't think the zf8 is all that picky about fluid as long as you don't go down the "lifetime" fluild route.
2016 328ix F31 - SOLD!
2006 997.1 C4S
Teutonic2709.00
      05-30-2020, 04:34 AM   #3
davidr3
Drives: 335i
As andino said, probably a rebranded fluid that's more expensive since it has a bmw logo on it.
Teutonic2709.00
      05-30-2020, 10:55 PM   #4
Rich.Wolfson
Thaumaturge
181
Drives: 2014 M235i
Originally Posted by andino View Post
I bought the zf fluid as part of a kit from fcpeuro....
Me too. The kit was wonderful, a good price and comes with a lifetime warranty. I will never use the warranty but that doesn't mean others can't.
If you do it yourself be sure to follow the procedures to the letter to be sure you get all the fluid out and the right amount back in. There are some good videos too with the full procedure. It's not a simple drain and replace.
///Rich
Teutonic2709.00
      05-31-2020, 06:03 AM   #5
Chihuahua
Chihuahua's Avatar
4075
Drives: E30 329iS, E65 Alpina B7
100% yes.
Teutonic2709.00
      05-31-2020, 05:08 PM   #6
Teutonic
Teutonic's Avatar
///Rich
Originally Posted by Chihuahua View Post
100% yes.
Hello all,
First of all thank you for all your replies.
I am however in limbo as the information I am gathering is kind of confusing.
This is the reply from ZF USA:
Thanks for contacting ZF in regards to your X1. The ZF fluid would be the Lifeguard Fluid 6 or BMW Oil No. 8322 0142516 which is used in all ZF equipped BMW's with 6HP transmissions.
The FCP Euro kit is cheaper than the dealer and honestly I will go for it just to be sure I have the OEM oil.
The problem is however that:
- The ZF is saying that my AT is a 6HP and suggests fluid 6.
- The kit suggested by the FCP Euro says 8HP
https://www.fcpeuro.com/products/bmw...-24118612901kt
My transmission is a 8 AT ZF, Should I presume that the code 8 refers to the 8 speed?
Also, is the kit missing the filter?
Thank you
      05-31-2020, 05:35 PM   #7
Gamb1t
Gamb1t's Avatar
Drives: 330i,X1,Z4,Solstice GXP, RX-8
Did they get confused with the X1 x35i which comes with the older zf6hp?
BTW there are a ton of zf8 transmission info over at the f30 forums. Also a wealth of info on the n20 engine which is shared with the X1 x28i.
Teutonic2709.00
      05-31-2020, 05:53 PM   #8
Teutonic
Teutonic's Avatar
That's my presumption as well.
      06-01-2020, 04:42 PM   #9
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Hello all,
Thank you
The filter is integrated into the oil pan.
The 8 denotes 8-speed.
ZF8HP, 6HP, 5HP, etc
If you're not certain as to whether you have a 6 or 8 sp you can look at the documentation which came with your vehicle or run a VIN decoder.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      06-01-2020, 05:52 PM   #10
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Redline D6 for 8HP, that or D4 for the 6HP.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      06-19-2020, 04:06 PM   #11
Gamb1t
Gamb1t's Avatar
Since you're in Canada, you can check out Canadian Tire. They have a new line called OEM brand. One of them is European MV LV transmission oil. It listed ZF 6-8 speed/vitesses compatibility.
The maker for this brand is Rechochem IIRC.
      06-21-2020, 11:33 PM   #12
Teutonic
Teutonic's Avatar
Ordered the set in US already and got the OEM oil and pan.
Thank you for the reply.
xbimmers
