      12-30-2008, 08:23 PM   #1
gonzo
gonzo's Avatar
Drives: as many as possible
Dinan HP Question.
Admins if you can leave this here long enough to, hopefully, get an answer I would appreciate it.
If this set up was done on an 02' M5 (400hp) does anyone have a close educated guess as to what the hp numbers "should" be? Crank or wheel. I could not find much on the motor pieces combination. Torque figure would be a bonus. Thanks.
Stage 5 Dinan software, Dinan carbon fiber cold air intake and upgrade kit, Dinan high flow air flow meters, Dinan high flow throttle bodies, full Dinan exhaust, Dinan 3.15 limited slip differential, Dinan stage 1 lightened flywheel, stainless steel brake hose kit, front and rear cross drilled rotors, Bekkers headers, Dinan front strut tower brace, Dinan rear shock tower brace.
Crazy Diamond
      12-30-2008, 08:40 PM   #2
gonzo
gonzo's Avatar
Never mind. I'll copy it for the curious. Good night....
I was looking up the wrong frig'n thing. Mucho stuff for 70hp......
Stage 5 Engine Software
High Flow Cold Air Intake
High Flow Air Mass Meters
High Flow Throttle Bodies & Velocity Stacks
Header System
Free Flow Exhaust
Stage 2 Suspension System
3.45 Limited Slip Differential
Stage 1 Lightweight Flywheel
Dinan Deck Lid Badge;
Serial Numbered S2- M5 Plaque
Peak Horsepower: 470 @ 6900 rpm
Peak Torque: 419 lb/ft @ 5000 rpm
Crazy Diamond
