12-01-2015, 11:04 AM | #1 |
Rep 713
Drives: e46 330ci, e92 335i, 2008 128i
Engine selection for a desired output
how does bmw, or any other manufacturer, decide what displacement engine to choose when by, for example, adjusting boost in a turbo app., they can easily arrive at the same total output for 2 engines of different displacements? for example, take the 320i in u.s. spec putting out 180hp/200ft-lbs, output that the 1.5l 3cyl could achieve if it's specific output were the same as the 2.0 4cyl in the 228? there are i'm sure pros and cons to each method, some of which may be marketing related as opposed to technical. specifically, with weight reduction a priority, wouldn't the smaller mill save substantial weight?
12-01-2015, 12:24 PM | #2 | |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
I have an i8 and the 228bhp from an FI-3 cylinders is very impressive. I lament the fact that they didn't go with the 4 cyl in the same state of tune which would have made the i8 a real supercar. Cheers-mk |
12-01-2015, 12:44 PM | #3 | |
Moderator
7515
Rep 19,368
Like you, I've wondered why the 320i still uses a 4 cylinder when the 3 cylinder should be sufficient. I'm sure costs must favor it for the time being in this application for some reason, even though it requires more material to manufacture. In time the I3 will likely take over as the standard engine at this power output. |
12-01-2015, 03:24 PM | #4 | |
Rep 713
12-02-2015, 12:57 PM | #5 |
Rather Ambivalent
380
Rep 755
BMW likes to use engines with cylinders measuring .5 liters of displacement each. That is the largest explanation behind the size of the engines that go in their cars. As for target power output, it's all maximizing cost savings, economy, packaging, and longevity.
Those 100+ hp/L engines look great on paper, and are typically fun to drive, but they pay a price in long-term reliability. The greater stress something is under, the shorter it's lifespan. It's a basic rule of engineering. While a 1.5T I3 and 2.0T I4 may make similar power levels, the I3 is working much harder to make it. |
12-03-2015, 09:28 PM | #6 |
European Editor
10589
Rep 22,992
Look at what BMW does with the diesel engines they offer... all of these are basically the same mechanical setup & displacement... just different software tuning... four, four cylinder engines using basically the same mechanical components.
4 cylinder engines: 316d - 85 kW [116 PS] 318d - 110 kW [150 PS] 320d Efficient Dynamics - 120 kW [163 PS] 320d - 140 kW [190 PS] 6 cylinder engines 325d - 160 kW [218 PS] 330d - 190 kW [258 PS] and... 335d - 230 kW [313 PS]
12-04-2015, 12:50 PM | #7 |
Moderator
7515
Rep 19,368
Dack, the motor in the 325d is actually an I4 now (it was an I6 in the E90 era though). Also, there is the 381PS N57S I6 at the very top of the range.
12-04-2015, 01:39 PM | #8 | |
#buildnotbought
10866
Rep 4,895
But also differences in brakes etc are common. That also adds up to the cost of a car. It's all about cost and filling in market segments.
12-15-2015, 08:15 AM | #9 |
Rep 1,447
Might be offtopic but how can they sell a X1 25i as a 28i in North America or a 530d as a 535d? Same goes for the 328d which is a glorified 320d finally back in 2011 the 330i has 272ps and now it's down to 252. I feel like the number doesn't mean much anyway.
12-15-2015, 09:31 AM | #10 | |
Rep 2,402
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
